KLX650 Idle Problem
Hi all
got my radiator / fan problem sorted but i have another problem now. :thumbsup:
problem is that the bike will start, run and idle fine. but if i twist the throttle it will rev fine but when i let go of the throttle the revs come down as normal but it cuts out instead of retuning to its normal idle??
it does this anytime i rev it...
any idea what this is ?? :ride:
thanks
I suggest checking/cleaning the air cutoff valve. Make sure no holes in it's diaphram. Check the small hole in the cover for blockage and make sure the o-ring is there and in good shape.
mine is the klx650 c model. where would the air cut off valve be? thanks
