Turn signal question
I just received my edge taillight and it looks like getting a pair/set of LED turn signals will be a lot easier to mount than the stockers. So my question is: can I run LED on the back and leave the stockers up front? If I have to go all 4 is there a relay issue anyway? I see lots of cheap LED signals out there (heck they all seem cheaper than stock) so the relay question is more important.
P.S. just went out for a ride in the snow. Sorry, I should say just went out to fall in the snow.
You can mix them as you please....Remember the led`s are polarized.....Good thing is that if you connect them and they don`t work....swap the wires around....:thumbsup::thumbsup:
Erling
i purchased my edge tail light with the LED flashers. because the rear are LED and the front are stock, a different amount of energy is used. all 4 blinkers blink at the same rate...the problem is that rate is fast!!! use a resistor if you go with the LEDS. i did and i love it.
Hello,
could you please tell me where exactly should I put the resistor?
Thanks
What size resistor and where do I install?
:banana:
It really depends on the energy consumption of your led array. But I`d go down to the shack, and pick up one of these.....
http://www.radioshack.com/product/index.jsp?productId=2062291&filterName=Type&filterValue=Power+resistors
or this.....
http://www.radioshack.com/product/index.jsp?productId=2062290&filterName=Type&filterValue=Power+resistors
These are meant to be used as load resistors.....Ie.....Not changing the voltage to your array ( blinker)....so they need to go parallel with the leads of your blinker wires.....In short....one end of the ress. goes to the negative....other to the positive.....Try the 10 ohm first....if that helps a little....but not enough....then try the 1 ohm......:):thumbsup:
Erling
Hello,
Thanks
See post above.....:):thumbsup:
Erling
Or go the solid state flasher method. I used the one from custom dynamics for the Z1000 (same pin size) I depinned the plug on the flasher and the drz. Connected the spades and shrink wrapped them. Clean and reversable.
I found an LED-compatible 7-pin flasher relay replacement on fleabay from a vendor named 'luckybike'.
It hasn't arrived yet, but hopefully its 100% plug-n-play. I'd rather not use load resistors as that defeats the power-saving benefit of going to LEDs in the first place.
I'll update when it arrives and I have a chance to test it out.
If you use a generic, solid state relay, you'll get a normal flash rate even if you mix LED flashers with incandescents.
You won't need to use any resistors. In fact, you can even get rid of the stock, 7-wire turnsignal-sidestand relay. Here's a very simple way to make it all work:
http://www.thumpertalk.com/forum/showthread.php?t=904989
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
