Latest SSW/MRD Revision jetting question!
Please and thank you for any help :thumbsup:
Just unpacked my SSW/MRD for my 07 SM which I suppose may be close enough to the original to use the same settings, but I don't want to assume:bonk:
3x3
K&N
New SSW/MRD
JD Jet Kit
All stock other then that!
Sea-Level!
What settings should i use :ride:
Thanks again!
The JD kit only has a 25 pilot in it, but I did buy the Kientech Extended screw from Forrest. I don't have a 22.5 pilot, should I go about tracking one down or should I just go with the stock screw? I'm not sure if there is any performance difference...
4 on the blue, is that the 4th from the bottom end, or the top end?
Thanks Eddie, very much appreciated!
Thanks npm. Awesome, I'm just dieing to install this thing. It's AWESOME! <3 Eddie & Dave for this one; I don't care at all if it is even 110db; I ride on the road in an area dominated by Harleys.
