Got the wrong Condenser but will it work
I got a honda condenser from ebay. They said it was for an xr80 but it is different from the original one. The PN is 30250-041-005. It has prongs instead of a wire coming off. I'm sure I could solder a wire onto it, but not sure if it will work in the first place. Any ideas?
All ignition capacitors have simular capacitance so it will work. If the capacitance is off for your system the points will wear faster than normal from arcing.
For such a small cheap item it seems to me that the dealer would be the best source considering the shipping cost with eBay.
the one you got was for a xr100 or xl80 that goes behind the flywheel yours should mount near the coil.you would have to solder a lead to it and find a way to mount it.best thing would be to get the right one.
