2002 CR 250R TT 38mm airstriker
My bike runs alright with the stock carb, but not as crisp as I want it to so I bought the TT 38mm airstriker with the jd jet kit.
I am in central TX (around 800 ft asl, anywhere from 50 to 100 degrees, and humid weather)
My bike has the following
Vforce reeds
FMF Fatty
Pro Circuit silencer
Wiseco Stock bore (fresh top end 2 hours on it)
Twin Air foam filter (no mods done to air box)
Stock Squish
The research that I have done is this, I am just not sure on what needle. I run EMN needle in my DRZ fcr which is real similar to JD's blue needle, I am not sure if that helps at all with this.
172 main
45 pilot
needle 3rd clip (blue I am guessing)
1.5 turns on airscrew
Does that sound about right? Thanks for the help.
Alright, I got the carb today. It didn't come with any instructions, it just said that it has been pre set for me at the following
172 main
45 pilot
AS 1.5 turns
blue needle 2nd clip
Do I need to set the float height same as stock, or should I just leave it alone. I measured and it looks to be set at 17mm right now. Should I run the blue needle 2nd clip?
Also when I am at the dunes, should I run it a bit richer with a 175 main?
