Oil leak on 2002 XR80
Noticed the little bike is leaking oil out of what appears to be where the gear shifter meets the crankcase. Will this part on bike bandit solve my woes: 9: OIL SEAL (11.6X23X10) (ARAI) 243078-001? Or perhaps something more hideous is occuring. I took a look at it and it seems the old seal is deformed and old on the top portion. Anyone else have/had a similar problem? Was it an easy fix? I will be purchasing a Clymer Manual soon. Thanks for any words that could help me.
Hmmm. . . the shaft looks straight. I took off the lever seems the actual housing on the case is cracked. Looks like a chip of it came off and the rubber seal is eroding. I don't see a long crack or anything on the crankcase just a piece of the metal surrounding the ring is missing, not awful I think the rubber gasket may be the culprit but obviously the small chunk of missing metal is not helping. I may need to take a picture so you can see what I am talking about.
probably not helping maybe you could jb weld the crack and replace the seal.
So is the rubber oil seal just placed in there via force? Don't have a manual handy and want to make sure I can just pull out the old one with the shaft still there (needle nose) and just wedge the new one in by hand over the shaft?
i would assume so but i have never had to replace mine so i dont know for sure
Get the old one out with a angled pick or something, then and a bit a grease to the new seal. Put a washer up against the seal and Get a deep socket or a little pipe to go over the shaft. Gently tap it onto place evenly. Hopefully, that will fix it.
Cool, now with the washer I am assuming that is just to get an even squeeze on the seal to make sure it is well placed? I know dumb question, just making sure you aren't saying anything about a washer permanently being there. Good advice, thank you!
  • Similar Content
    • By Daniel627
      A while back I picked up a '95 XR250R swingarm that I plan on installing on my '90 XR200R in the near future, to save a little weight and have rear disk brakes.
      I missed out on a totally complete rear brake system for $75 a while back which sucks. I look on Ebay every now and then hoping to find a great deal on a complete or near complete setup but no luck lately.
      Is anyone aware if Honda used the same brake system that was used on the '90-'95 XR250R, on any other bikes?
      If so, then I can expand my search. If not, then I'll just keep looking at 250 parts til I find the right setup for the right price.
    • By riverside21
      Has anybody purchased/used one of these Arrowhead IHA6017 cdi boxes??  I tried 2 different ones of these on a 1987 and 1994 XR200R, and the bikes won't even start.  Bikes just pop and backfire, had to put the old cdi's back on.  I noticed when I ordered the boxes they stated "advance ignition curves" in the specs.  The box is also much bigger than the stocker and won't fit in the rubber mount.  I didn't mess with moving around the timing to try and get these to work....I just sent them back.
    • By riverside21
      Recently picked up a 1987 xr200r in pretty good condition, all stock.  The carb was all gummed up and running real rich, and the previous owner removed the baffle and end cap from the exhaust, but left the air box top chute in place.  I cleaned up the carb and verified all stock jetting, needle position, air screw, etc.  Where we live the quieter the better for off-roading so I ordered a new baffle and end cap, but did ride the bike for a week before the parts arrived.  With the muffler parts out I had a brown plug and plenty of power throughout the entire throttle range.  Got the muffler parts, installed them and now the bike falls flat while climbing hills and gradually rolling on the throttle, I get a burble at low speed sometimes and I have a black sooty plug.  I'm kind of at a loss on this one.  I realize that the parts restricted the exhaust....but it's basically back to stock and I've had these bikes stock before and they ran fine.  Seeing as I have all stock jets and am getting a sooty plug, I'm wondering if electrics are weak?  I also tried adjusting the air screw in/out and moving the needle clip to position 2, either of the two made my problem worse.
      Any ideas?
    • By riverside21
      So the other day I notice that the rear shock spring on our 1994 xr200r had cracked and separated about 2 coils from the top.  No big I thought....just go on Ebay and pick something.  Well, after a few days of looking I can't find ANYTHING used or aftermarket!  The stock Honda spring #52401-KT0-691 is "no longer available".  Can anybody lead me in the right direction to get a replacement spring for this bike??
      Thanks in advance.
    • By hondamaster1
      I have a 1999 xr200r. I used to ride it like a champ than i stored it for a year getting it out once in a while to run. Than i took it out a couple days ago started it and it ran and died instantly. I cleaned out the carb put everything back together and still sane thing. You have to feather the throttle to keep it running. It also made a loud pop and it jerks you when you ride it. I changed the spark plug, cleaned the carb, and put new gas in the tank. Any ideas? Wanted to ride it this weekend...
