06 crf 250r falling apart
I need to know what would make oil leak around where the shifter goes into the case is that something that needs a shop or is there a way to DIY? thanks in advance to all helpers
ya theres a seal around it. call a honda house and hopefully it can be installed from the out side but sometimes you have to split the case to get to it from the inside (rare). if its a newer bike you should be able to do it from the outside.
DIY, buy a new seal, remove old seal with a pick or a small sharp screw, put grease on the seal, a piece of plastic on the shifter shaft like a condom, and slide the new seal on careful not to rip it.
or pull the outer right side case off pull the shifter shaft, replace seal and reassemble.
