kick stand kill switch
I removed my harness from under the seat down to the kick stand. Then I made a jumper wire to plug back into the connector under the seat. No soldering needed & it can be reconnected.
JD
I used a piece of aluminum angle that bolts up behind the switch and holds it closed like the kickstand is in up position.
I cut the two wires about an inch and a half past the plug under the seat soldered the wires together used a little heat shrink wrap good as new :thumbsup: and unbolted the junk kill switch!!!
