Chain stretch question
I suppose I had my chain adjusted to tight or barely to tight, I noticed after my last ride that included some small air time and hard hits that it was a fair bit looser then when I started the ride.
So what's the dealio there, can I adjust it up or should I replace the chain sooner then later. I run 15/50 gearing, what the ideal chain length and type to run. My local supplier offers a few options.
What is the first number representing?
For example.. DID o-ring chain 420-110 links. or 428,520 etc etc..
Then of course theres V series, VT, ZVM2 and so on
Are you sure the axle nut was tight and the axle has not move forwards?
Service limits: 21 pins 319.4mm
DID 520VM X ring, Don,t know how many links with your gearing.
Pretty sure it didn't move forward.. although I did stop using the cotter pin on the same run. What's the 520 stand for?
You should torq it, 520 is what yours takes, I belive it's the size of the links.
Yeah I'm going to tighten it and run it for a few more rides, I just bought a pit bike so I'm kinda on the cheap for a few months.
I hear Ya, Keep an I on your chain things happen.
Yeah I saw that a few days ago...
Mine has way more where then that one, but I do check it before every ride.
Chain numbers refer to pitch and width. 520 is 5/8 pitch (distance pin to pin) and 1/4 wide (thickness of the sprocket teeth). The sprocket is actually thinner for clearance. 530 is 5/8 by 3/8. All the rest of the mumbo jumbo is brand specific.
Thanks that makes a little more sense.
Although I was told an easy way to tell if the chain is toast tonight.
Adjust for proper tension.
stand the bike up, pull the chain at the 3 o'clock postion on the rear sprocket.
Put a light behind it.
If you can see light, it's done.
Replace it.
Seems like science to me.
But it's going to have to wait for another month or two.
