2001 yz250 water pump issue
hey all,
i just got my bike back together after blowing up the piston and, while conducting the break in, i noticed coolant spitting from the relief hole on the bottom of the water pump. what does this mean? it was working fine before i took it apart to rebuild the top end. do i need to lube or replace something? thanks for the help!
-litewatefitr-
I had the exact same problem with my 2001 YZ250 last year while vacationing down in Florida,, It is the outer seal in the water pump,, it's right behind the propeller,, the hardest thing was finding one, (we drove all over florida to get one),, you will probaly have to order one, very easy to replace,,, i hope this helps,,,
jeff
373
