cam shaft question
It may be pressed on. If it isn't sliding off the shaft splines easily, then it's either pressed on(interference fit) or there's some corrosion going on(I'm skeptical about that).
If pressed on, then it will need pressed off. Heating the sprocket flange will help it come off easier.
never mind,
it simply came off with a puller
thanks
Edited by fiep
