Rookie Jetting a 00'YZ426F
I've never messed with the carb(intimidates me). But now that I have installed the FMF Powerbomb and Powercore muffler I'm in need of re-jetting. After install bike started right up and had noticeable low-end power increase, but when at slow speeds in would stall out. Also, it almost sounded like it was hissing.
Current jetting is stock:
Main Jet: 162
Pilot Jet: 42
Starter Jet: 72
Leak Jet (if any): N/A
Fuel screw/Setting: 1.25 - 2.0 turns out
Needle/Position: OBEK4
2000 YZ426F
Elevation:4400'-10000'
Temp:75-100f
Humidity: Very Low
Single Track Riding
FMF Powerbomb
FMF Powercore
Stock Motor
Twin Air Filter
What do you recommend as a starting point? Thanks in advanced for any input.
i just put same system on mine,,,current jets are 48pilot,178 main,,no bog,totally smooth,,,i thought that would be way too much jet,,,but i changed em in stages and it works best,,,good luck
In Denver at 5800 feet that bike needs a 155 main. You shouldn't need more than a 158 down at 4500. The fuel screw should be more like 1.75 turns out.
