Will a GYTR baffle make my bike run richer?
Still trying to sort the jetting on my new to me 2007 WR -Arizona @ 3000 ft or so.
Right now I'm running
165 MJ
42 PJ
70 LJ
Still has the AIS, but most of the other uncorking has been done, including completely removing the exhaust baffle, which is too loud for my taste.
Currently it seems a bit lean off the bottom, but runs great up top. Has a little bog off the bottom, which I'm hoping to cure w/ a 40 or 50 LJ. Additionally, I've been planning to order a 45 PJ
If I go with the GYTR or PMB exhaust baffle, will that make the bike richer, enough that I probably won't need the 45 PJ? I'm currently 3 turns out on the fuel screw....
I guess I'm asking if the GYTR baffle will make a difference in jetting over nothing at all, other than the SA...
Edited by skopiec
I think it's the stock WR needle - an adjustable YZ needle is on my list, but I didnt think it would play into the leaness/bog at the bottom.
if its running lean you may want to put in that adjustable needle and go lower on the clip to give it a little more gas..also a 40 leak jet works wonders for these bikes
Get the 40 LJ in there and then see where you're at. That's step 1.
Maybe, but where will it be richer (low, mid, high)? The concern your asking about is controlled by the pilot jet, so replace it.
Just ordered a:
NHKR needle
40 LJ
45 Pilot
170 main
I'll change them out 1 at a time and report back the results....
