2005 125 clutch problem
Hello everyone, I have done a search and have not found a similar problem. I have a 2005 YZ125 and I just put OEM clutch plates, fibers and springs and a GYTR inner basket #GYT-5XE56-40-00. Now I am no MMI tech, but I feel like I am familiar with wrenching on dirtbikes. Installed all parts with fresh oil and now I have zero freeplay, no matter how much I adjust, now the activation arm is even hitting the bottom inside ignition cover. The lever is almost banjo string tight. The pushrod and BB are installed correctly. I am at a loss, I have had the clutch cover off about 3 times. I have tried to ride it the bike barely moves. Any help would be greatly appreciated. Thanks, Doug
check your cable to make sure its moving freely... Ive seen alot of ppl with similar problems and after they replaced the cable they had no more issues.
