Anywhere know where this goes?
The one I'm holding. I've heard it goes to the petcock which is obviously incorrect since there are two leads off the petcock, one being the main which you can clearly see enter the carb, the other you can see hooks around the carb and enters near where the throttle cable attaches. I Just removed the smog canister, capped the port on the bottom left side of the carb and then found this thing dangling. Just wanna make sure its not supposed to attach to anything.
Could it be a vent port to relieve pressure from the piston that holds the needle moving up and down? Just a guess
i do believe its just a vent. there should be some sort of retainer holding it in place but mine just hangs down as pictured above
Thanks guys won't worry about it anymore and I see the retainer now. Must have forgot to reattach it when I rejetted.
