how much gear oil should i put in my crf250r 07
Hi i have just bought a crf250r 07 and i now want change the oil but i am not sure how much oil to put in the gear side. i have been by a friend who have a crf450x 06 that i might need to put more gear oil in then it says on the engine caseing as one of the gears might not get enough oil if i put the standard amount in. is this true? thanks
you could remove the 10mm bolt on the right side of the engine and fill the oil slowly until it runs out the hole. but if you want to maintain this bike to the fullest you should purchase a manual.
If it's the same as an 08, which it probably is. 600ml (0.63 US quarts) for transmission oil.
I put in about 800 ml for a full drain/change.
just put in 825cc's and call it good, dont ever go by the check bolt's.. do a search and you will find that many guys are running 825cc'c
thanks for all the replys. ive purchased a manual and it says to 700ml in the gear side. give me shout if u reckon thats wrong and i should more in. cheers
