Will 08 showa spring fit 09 kayaba shock?
Hey guys,
My friends got an 08 crf450 with a lighter spring in the rear and I was looking to try it out on my 09 crf450. Was wondering if the springs are interchangeable between the 08 showa shock and the 09 kayaba shock?
Thanks
i fitted a 06 crf spring to a 2010 yzf 450.Fitted fine.
The CRF and KXF, '09 and '10, are a larger ID spring. The '08 spring will not fit. The YZF shock springs are the same ID as they've been for over a decade.
Its not a great fit but it will work as a tester. The Showa spring is a little longer and a little bigger in diameter. It is best to use a small collar like the ones that come with Factory Connection springs. You may also have to use a spring compressor to get the preload rings to start on the threads.
sorry, i thought the 09had the big 50mm body like the 2010 yzf ,it doesnt like Richard says its the std kyb spring you want it fits right back to a 1992 cr 125.
