Help please 74 elsinore running crazy?
Ok where to start, i bought a honda elsinore MT250, it didnt run all that well so i bought a carb rebuild kit. so i rebuilt the carb and it will not run without the choke on, it seems not to responde to needle changes as well. i rode it around the block to try and clean it out. it statred really smoky. after about a 1/4mile ride when i returned the throttle back to closed position the motor didnt seem to wind down instantly, so it seems that it is running too lean. I went back to the garage started the bike after 10 min of kicking it finally fired ran for 10 -15 sec the the motor rpm's shot up super high. i mean crazy high so i turned the kill switch, nothing pulled the spark plug wire, nothing still running (this is my first experience w a motor running with no plug wire so i am freaking out.) finally i pull the fuel line after 20 sec it dies. whew. I noticed this morning that the trans has no more oil in it, is there a possibility that some of the smoke commig out of the motor was trans oil due to bad crank seals?
You have bad crank seals, the engine has a massive air leak. You are going to need to split the cases and replace the seals.
Yes, you were burning the trans oil. This is why the engine was running so lean and not returning to idle.
Fix the problem or you are going to seize the engine.
  • Similar Content
    • By D.Barrett
      Kicking around the idea of selling my CR250. I have other bikes and never get a chance to ride this one.
      This is a well-maintained bike with tons of aftermarket parts. It's set up primarily for woods/single-track riding, but will still do just fine on an MX track.
      Engine:
      -Fresh Pro-X top end(<1 hour)
      -FMF Gnarly pipe & FMF Shorty silencer(<1 hour on fresh packing)
      -PWK Air-Striker Carburetor(bought new from JD Jetting last year)
      -Steahy 10oz. Flywheel Weight
      -Boyesen Rad Valve with Carbon-fiber reeds
      -TwinAir air filter
      Misc:
      -Excel Pro-Series Wheels(19"/21")
      -Brand-new Shinko tires(546 Front, 505 Cheater Rear not mounted yet) w/ Heavy-duty tubes
      -Works Connection Radiator Guards
      -Skid Plate
      -FMF Factory 909 Handlebars
      -Polished Frame
      -Sunstar 13/51 Steel Sprockets(new in box)
      I'm sure I'm missing a few odds and ends. Comes with a Bill of Sale only. (708)287-1998 - Dave
    • By waldo
      Parting out 2000 cr 250r: frame 150.00, seat with brand new fx cover 30.00, sub frame 30.00, pro circuit works pipe 50.00, kick starter 10 bucks, tank with shrouds 30.00, rear shock 45.00, swing arm 40.00.  make offer on all other parts in picture. Buyer pays shipping from 36092 zip.
    • By BabyGroot69
      Hello,
      I could not seem to find a similar thread so if one exists I apologize. I have an 02 cr250r with an 01 motor. I need to buy a new silencer with a spark arrestor because the current one does not have one. I am not sure if the owner before me used an 01 or 02 silencer because I have read the frame had significant changes from 01 to 02. Any thoughts? Thanks!
    • By Christo6060
      I want to restore a 1996 cr80 that doesn’t have any graphics and absolutely love the 1994 cr125r tank shroud graphics, I can’t seem to find anything that fits the cr80 with those graphics. I found one last week but lost the page and couldn’t track it down again, do the cr125r graphics fit the cr80 tank shrouds? or does anyone know where someone could make them for cheap or know about any in Australia
    • By cerialsledder
      Hey guys,
      Could someone please explain the numbers on a needle jet for a mikuni carb?  I'm currently running a 38-73 needle but a lot of the people I talk to say I would be happier running a 38-70 needle.  I don't have a problem with going with what other recommend but I would like to understand the numbering for the needles first.  I understand the nozzle sizes, main jet and pilot jet it's just this damn needle thingamobob
      Thanks a lot
