06 Kx250f knocking noise
Hi, I have a 2006 kx250f that's making a very loud knocking noise coming from what I thought was the top end, the noise wasn’t very noticeable at first but after 30-40 minutes of running on a track it became very loud. The bike has recently had a new piston and cam chain, hotrods conrod kit fitted, and also I've recently fitted an 07 transmission in as the 06 transmission destroyed itself! These parts have only had about 2-3 rides on them. I sent the cylinder head away to have it checked out for any possibly causes but that came back fine, I've also measured the piston and cylinder to check the clearance between them but that is within spec. What else could be causing this noise?:thumbsup:
Thanks
Did you replace the crank bearings when the crank was installed?
Yup they were replaced.
Possibility who rebuilt your crank didn't not ballence it right or the Conroe bearing was damaged.
If that was the case surely the noise would have started after I rebuilt it? Its had a few rides after the crank rebuild with no problems?
  • Similar Content
    • By Toms.abpg
      Just bought this bike and the pop on decel is horrible, looks like I’m gunna have to try a Tokyo mods remap. Anyone had success with this ?
    • By _Cloudy_
      Hi, I have just bought a kx250f, 2013 with a freshly rebuilt 2016 motor in it, this is my first time on these forums, anyways, I have also bought a lowering link to drop it 4 inches on the arse, I was wondering if anyone knows how much I should drop the forks?
      I havent put the lowering link on yet.
      Thanks.
    • By Zach Miner
      Recently had issues with the original fcr carburator that was installed in my 2009 kx250f, tried jetting multiple time and different gas and the bike would only run with the choke ziptied out. Do I went ahead and purchased the lectron gen 2 4 stroke carburator kit, was kinda expensive and I was kind sceptical but after my first ride all I got to say is wow. The only adjustment I have done it set the idle, the bike runs amazing and feels as if there is more power than before. The kit came with a new throttle tube assembly and a g2 throttle tube with adjustable cams for throttle response. I highly recommend if you have a carburator on your four stroke and don't want to get a new dirtbike that is fuel injection then go the route of throwing out that junk fcr carburator and get a lectron gen 2 carburator for your old 4 stroke
    • By DirtbikeDon
      I own a 2012 Kx250F that I would like to make street legal if possible and I recently saw Rocky mountain I believe sells these battery packs that sit in the airbox for bikes without batteries that looks too good to be true and a headlight and turn signals like a conversion kit basically and I was curious as if anyone has had luck with those or if there junk it would be nice to make my bike street legal for short trips or just have lights for trail riding with friends that already do if possible any tips on converting it?
    • By kylesmith_14
      The launch control only lights up when you first start up the bike when you try to use the launch control it doesnt light up at all ive tried 1st 2nd and neutral for 3+ seconds ive cleaned the connections and also cleaned the neutral saftey switch or gear selector and still no luck any help would be appreciated
