Crf70 not running!!
I have a crf70 i never ride anymore and wanting to sell it but it will only run with the choke on, once i take the choke off it revs real high then dies.:ride: I have already cleaned the carb but maybe i didnt clean it well enough? Please help!:thumbsup:
gunk in the pilot jet =\
spray carb cleaner directly THROUGH the pilot jet, and maybe use a small piece of wire or something to clean it
I think the pilot jet is NOT removable on the 70's just like the 50's :thumbsup:
Carbs must be very very very clean, if you aren't going to make it spotless then there is no point in even taking it apart as you are just wasting your time. As Towliee says, make sure all jets and passages are clean, you should be able to clearly see through both jets, just be careful when you use a peice of wire so you don't enlarge the hole. You didn't mention what year your CRF was but I believe the plot jet is removable.
