bg10459
Crankshaft Primary Drive Gear???? PLEASE Help!!
I'm rebuilding my 02 YZ250 and I have a question about the thrust washer that goes under the primary drive gear on the right side crankshaft. (#2 in this diagram -> http://shop.thumpertalk.com/oem.asp?partcategory=52665&manufacturer=6&category=3&year=2002&model=1291). The manual (and the linked diagram) clearly show that the thrust washer goes first, followed by big gear, small gear, washer and bolt. The problem I see is the thrust washer is splined like the crankshaft, but there is a slot in the crank where the thrust washer sits where there is no spline which would allow it to move off center. Is this the way it's supposed to be? or am I missing something? When I spin the crank, I can already see the thrust washer isn't perfectly concentric, and I would imagine it would only get worse when the engine revs.
I'm certain the fine folks here can help me, so I express my gratitude in advance :thumbsup:.
Edited by bg10459
I don't remember having an issue with this.
Maybe this pic will help.
Good luck !
Yeap that is correct.
I'm rebuilding my 02 YZ250 and I have a question about the thrust washer that goes under the primary drive gear on the right side crankshaft. (#2 in this diagram -> http://shop.thumpertalk.com/oem.asp?partcategory=52665&manufacturer=6&category=3&year=2002&model=1291). The manual (and the linked diagram) clearly show that the thrust washer goes first, followed by big gear, small gear, washer and bolt. The problem I see is the thrust washer is splined like the crankshaft, but there is a slot in the crank where the thrust washer sits where there is no spline which would allow it to move off center. Is this the way it's supposed to be? or am I missing something? When I spin the crank, I can already see the thrust washer isn't perfectly concentric, and I would imagine it would only get worse when the engine revs. I'm certain the fine folks here can help me, so I express my gratitude in advance :smirk:.
That is correct, just put it in and forget about it
I went around and round with the same thing when putting my bike back together after installing the WR trans. I was very careful to keep everything together just as it came apart during the tear down so I knew that's how it came from Yamaha but it still didn't look right.
Well, I did just put it together and all is well almost two years and many many miles later...
My son and I just ran into this same issue on his 02 250. IMHO, this design sucks I was thinking of adding a plump O-Ring under the ring to keep it centered and "balance" it out. Does anybody else think that's a good idea or foresee any problems from doing that?
I put a hotrods crank in my bike about 15 hours ago. Long story short, I've been searching for answers as to why I have more vibration than a new crank should. I spoke with my friend who rebuilt the engine and he says he was sure that the crank runout was in-spec. He advised that I check the primary drive bolt was tight, which I did about 10 hours ago.
Long story short, my primary gear bolt came loose on Sunday and tore a hole in the inner clutch cover. :rant:
I never turned the primary gear to check that this washer was centered, but I wonder if this runout could have caused the vibration and eventual loosening of the bolt.
If anyone has an inner clutch cover for sale, please let me know.
And if you have experience with repairing the threads in the crank ... I've ordered a new bolt, but the threads were very smashed on the bolt.
Hi
I am dealing with the same problem now ! Bike left me stranded in the middle of nowhere! Putting it tigether and I observed the same thing . The splined washed just dis not look right just sitting there off center and loose .
From a 'mechanical sympathy' perspective, I really hate this design.  You've got it assembled correctly, it's just wierd.
From an engineering perspective, there's absolutely nothing wrong with it.  It's just a spacer and is so lightweight and small diameter that the imbalance is imperceptible.
As to the bolts working out - lots of loctite and torque to spec.  It's a known issue with that bolt, but if you're careful assembling, you won't have a problem.
  • Similar Content
    • By Lone Danger
      Ok so I'm looking for opinions from those who have been on yz125s and 150 exc/xcw's and maybe the ktm 200's exc/xcw's. You gotta be out there.
      Here's the deal...I'm 5'7" 165lbs. A couple years back I was looking for a small bike for my wife to learn on and for me to play around with and race. Could only afford one bike. I got a '09 ktm 105 sx. Once I got it sprung for my weight it was great. I have been top five consistently in my local harescrambles B class, believe it or not. Ya, you were not the only ones shocked. And did pretty good in the local mx races as well, junior class up here in Canada. Lack of power was sometimes an issue but I learned to deal with it and just scream, scream, scream!
      However my wife is a complete beginner and she is scared of it. I have since moved her to a 4 stroke.
      Just got a mint '01 yz15 mid summer. Like less than 200 hrs! I have absolutely loved it on the mx track. Suspension is perfect and I love the extra power. I had planned to set it up for woods/mx with a suspension revalve. However, did a harescramble race a month ago that was really technical. Granted I have not done anything to the suspension minus clickers, had too much psi in the tires (13 front and 15 rear) (yes I know that's wonkey, I only had time to get a heavy duty tube in the front and had a stock tube in back. Less psi in the back would have been instant pinch flat because its so rocky) and it was running rich. I had to scream the thing to keep it running and even changed a plug mid race. Well I'm sure you can guess but it was the worst experience I have ever had on a motorcycle. The more open sections I passed a lot of people but the tech sections required way more effort than I liked and the suspension beat the hell out of me!!! Like my knees, wrists, and shoulders were just done. (I was out there for three hours).
      So keep in mind that I just came off a 105sx with suspension mods (set up for woods/mx). I have no problem slipping clutch and shifting precisely, yatta yatta. (I don't think the 105 would have done well here either due to even less power, however...) I've been second guessing fixing this 125 up for woods ever since I rode a friends '09 ktm 250xcw. I rode it on a local mx track. The power was just so effortless and I was absolutely floored by how the suspension worked. I never thought that I could hit the woops that hard and clear every jump on the track on an xcw and feel THAT good! It felt a lot heavier though, and I think the price tag on these things are going to be a stretch.
      So here's my question. I want the lightness of a 125, but want to be able to race both woods and mx. How does a 150 exc/xcw ENGINE compare to an mx 125 engine? I love the 125 engine, but more low end would be usefull in tech areas. But if there is not a huge difference, I will probably just revalve the yz for woods and go tubless, etc. The 150exc's are so expensive and I hardly ever even see one for sale unless its brand new. I don't want the weight of a 200/250/300. I barely touch the ground on a 125....so it has to at least be light. Is it worth waiting for a 150 engine? Thanks guys.
    • By doolan
      Hi guys I have a 2018 yz250 looking at changing springs front and rear I'm 200 pound ride b class moto.
      Having problems choosing spring weights using the calculators as mx tech say I need .45 fork springs and 5.2 rear but racetech say .48kg forks and 5.8kg rear.
      What are other bigger guys
    • By YamahaYz1
      Hey TT, I know there's endless topics on YZ250/ two stroke tuning in general but I have not been able to find one that helps me get my 09 YZ250 set up for my riding style and where I ride so I'm here asking for help. I got this bike around 1.5 years ago and have not known how to set it up properly. I know no one can give me a perfect set up but I'd like a good starting setup to work from and tweak to perfection. Throughout this time I've had this bike, its always been covering the bottom of the entire silencer and dripping all over the swing arm and rims with oil. Also, the joint between silencer and expansion pipe has oil around it too but I've heard I have to close the gap a little to squeeze the silencer a little tighter and stop the leakage there. I don't have too much experience messing with carbs but I've messed around with previous two strokes and tuned them a little better. I change the oil on my bike after 15-20 hours on it and clean and oil the air filter after almost every ride. The sparkplugs never last me more than a few months but recently have been lasting me no more than a few weeks. With the excess oil from the pipe and spark plug fouling you can see why I need to set my bike up to stop this.
      The bike:
      Completely stock with V-Force 3 Reeds and a FMF Shorty silencer.
      Usually running around 32:1 premix with 91 pump fuel because I prefer to keep it well lubricated instead of running rich.
      Riding:
      I ride enduro in Ontario, Canada. So mostly single track and some fire roads but nothing close to MX and not a lot of time wide open. Therefore, probably mostly 1/4-1/2 or 1/4-3/4 throttle range.
      Where I ride:
      Usually 0-500' above sea level. With temperatures ranging from around 15-35 degrees Celsius (55-95 Fahrenheit).
      If anyone can give me a setup to go from, that would be very much appreciated. Even multiple set ups for different temperature ranges or any suggestions would be much appreciated. Thanks and sorry for the long read, I just didn't want to leave anything out. Ask any questions if you have any, too.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
