2005 KX 125 - Rear Shock, oil leak
Hey guys. My rear shock isn't blown, however, there is oil on the shaft. Leaving me to think the seals are no good. However, when I look online, there are too many seals/kits to pick from, and frankly I dont know which one to get. Can someone please get me a link, or tell me which kit I need to rebuild this rear shock (as far as oil, quantity, and PSI for nitrogen? Thanks.
Hey guys. My rear shock isn't blown, however, there is oil on the shaft. .
That means the shock seal IS blown. Just order a new seal head assy. Use a good quality shock fluid with 150 psi.
doc
lots of kyb shokcs have corrosion or wear on the rods.
Doc, which weight oil should I be running in the shock/forks? And can I get the stock settings for Fork and Shock rebound/compression? Or even better yet, can you recommend settings for a 190 pound, 100% MX, B level rider? Thanks.
