Optimum CR for a 470cc stroker with RHC cams?
Given I have 98 gas available, who knows what the optimum compression ratio is for a 470cc stroker (94mm piston) with RHC cams? I'm trying to make pretty big power though I can't afford the springs and valves just yet so the head will be stock with the exception of the new cams...
Oh I know he does :thumbsup: I'm hoping he will drop in soon.
I would be really worried about a stock valve train with rhc cams. You will have a lot of money in the engine to drop a valve and destroy it.
+ one on that , i really want +4mm stroker on my bb bike but i haven't the money for the proper cams , springs and valves...
Patience Svery..!
what are you using the bike for? what fuel will you be running?
Mainly street and a bit of track. I use BP ultimate 98 here in NZ. I didn't realise the RHC cams put that much extra stress on the valves, don't they mainly have greater duration rather than lift?
The bike is fitted with a fat stainless header, 39mm FCR and Procircuit T4 muffler.
Edited by Svery
there is more to it than just duration. dont forget with the added duration you have much less of a cushion space for error getting the valve out of the way of the piston or each other.
luckily with the carb and pipe you have it wont make power that high effectively so you will be short shifting alot any way.that will help your spring situation.
i would go with 3 base gasket layers total.1 on the top of the spacer 2 on the bottom.
Yeah, ok - I'm not too worried about valve float as I don't wring it out that much - but I would have thought my exhaust system is fairly free flowing with the big fat header and T4...? If not, what muffler is the preference in this situation?
Is it the carb (39 v 41mm) thats the main breathing issue at higher rpm? Thanks Eddie.
the pipe and carb.
there only 2 pipes made for a drz that will supprt more than 44-46hp.
thats yosh ti ($900) and the MRD/SSW ($470).
its not just the muffler.
The cams also have much steeper ramps. You really do need the springs to go with the cam if you want it to live very long.
weve done what we can to keep the opening and closing velocity in check with 187's but the fact of the matter is they are faster.not much you can do about other than try and keep the valves in control as much as you can with the proper spring (seat pressure,over the nose etc).
stock springs arent horrible. just heavy which in itself makes them work harder.
watch the bmw valve train video thats floating around. makes the jaws drop of people that had no idea whats going on in there.
it wonder we can make them live at all really.
Oh well, guess its time to save....
Three layers of base gasket (0.25mm each layer) along with the 2.25mm spacer and cometic three layer head gasket yields a CR of 12:1 (according to the software program I wrote). I used digital micrometer to measure up the various thicknesses.
I was thinking more like 13:1 but perhaps the stroker prefers something lower than this....
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
