lets see pics of 01/02 yz 250f's
i would like to see what you have all done with the 01's like graphics and stuff
Dont get too down bud, there probably aint a lot of these things around anymore.
i have one but no graphics
i know theres not many around but i really like the 01s
they cant of all disappeared
they look awesome
where did you get the grahpics
have you done the auto decomp mod, was it worth it
what cam did you use(if you done the mod), did you have to reshim
Factory colors from Factory Effex have about the most WORKS looking decals. I had a white tank and the decals will not stay on then the tank gets dirty and you can not clean it off so Blue works the best.
I use sticker's as well from about every manufacturer I have bought something from so this can add a unique look as well.
List below.........
FMF Q4 Pipe Est. 1 Horsepower Increase
FMF Megabomb Header Est. 1 Horsepower Increase
Athena 290 Big Bore Est. 5 Horsepower Increase
Rekluse Automatic Clutch Est. 30% Increase in Traction
Nutech No Tube System Run 8-10Lbs. Increased Traction
Scott Steering Stabilizer
Scott Rear Disc Alum. Protector
R&D Power Valve Very Clean Low to Mid range RPM's
Boysen Accelerator Pump with Hot Start Cable/Lever
TM Design Chain Guard Damage Proof Phonlic Material
Acerbis Handlebar Protectors Alum./Plastic Hand Protection
YZ Cams, Intake and Exhaust Est. 1 Horsepower Increase
Vapor - Tacometer/Speedometer/Engine Temp.
Precision Concepts Revalve and Intrenal Polishing
Loudmouth MX Airfilter System Est. 1 Horsepower Increase, Very Easy Plastic Frame with Hose Clamp System
Plastic Frame Guards Protect the Blue color of frame
Leg Pegs All time or Long Distance Leg Support to be in the attack position
Rekluse Rear Brake/Front Left Hand Lever system Finesse Braking Downhill or Lazy Sit down rear Braking
Ergo 2 throttle System 10% Larger diamater to open throttle quicker and reduce the twist distance
Renthal Non O ring Gold Chain Lighter and Stronger
Renthal Twin Ring 52 Tooth Rear Sprocket Lighter and Stronger
12 Tooth Front Sprocket Geared down for 8 to 58 mph conditions
Note I use the Factory WR and insert 300 before the F since this is an Athena big bore.
Tony
Edited by sdTony
they look awesome
The Auto Decomp is totally worth it.!!!!!!!! Easy to install and change. Do it..
Get a yz250f cam off a 03-09 and no reshim required.
are you sure a 04 plus cam will work i thought it was only the 03 cam that worked
what about a hotcam, better or worse than OEM
and then I did it in RED :banana: I designed the shroud graphics and sent them to ResenMX.com to have them printed. The rest of the graphics was a FLU designs kit that I got off of eBay. I wish that I never sold that bike.
they look awesome
Thanks if you meant mine! They are factory effex graphics got them off the net, Havent done auto decomp, doesnt really bother me, have sorted a hotcam auto decomp for when this cams knackered though! Engines in bits at the moment anyway so could do it now i guess! You decided on some graphics yet?
yes , its cuase everyone uses a 03 cam or has heard everyone says 03 , its like word spread on the 03 only but 03-09 fits mine was a 05 i think , hot cams are better if you can get the pair.
i might just get the exhaust cam me only being able to afford the exhaust for now
all your bikes look sick!
do your bikes ever get scratched?, mine has scratches all over from riding,
i have to get the scratches out of my plastics now before i get the graphics
stunning but i wont think it will be far away....no chain ! :lol:
stunning but i wont think it will be far away....no chain ! :banana:
LOL...that greasy chain gets on my bling! :lol:
