Pilot Jet part number change?
Just curious if anyone else has run into this.
I got my power up parts from my Honda dealer, and like an idiot, didn't check the part numbers against what I ordered. Got home and put in the Needle and Main Jet... and then noticed that the Pilot (Honda calls it the Slow Jet) was a different number than what I ordered.
I ordered part# 99103-MT2-0450, and what came in was 99103-KPS-0450. I took the part back to the dealer, and the guy said that the MT2 listing has been superseded by the KPS. He showed it to me on the computer.
Here's a pic of the new part:
So... me being a complete noob with doing this mod... doing any kind of carb work... I wanted to check if I'm good to go with this before I try to install it in my '05 CRF230F.
Anybody else experience this?
Thanks.
BTW: Here's my complete parts list:
Needle: 16012-KPS-921
Main: 99113-GHB-1320
Pilot: 99103-MT2-0450 (now 99103-KPS-0450??)
Thanks.
The 99103-MT2-0450 has been replaced by the 99103-KPS-0450.
HERE is the parts breakdown for the carb. If you scroll down the parts list to part 31. JET (#45) you will see the note about there being a new number.
Thanks for info! :thumbsup:
  • Similar Content
    • By hondahondo
      A few picks of my winter project.
    • By Australian Psycho
      So I want to fit a Speedo to my stock Honda CRF230F, I know people have fitted the Trail Tech endurance to them but they are a bit pricey so my questions are is there another reliable Speedo or is my best choice to bite the bullet and get the Endurance? My other question is the stock stator for the CRF230F enough to power a Speedo or more specifically a trail tech endurance 2? I fully capable of installing it and splicing the wiring, my question is just can the stock bike support it? Also the Bike does not have a headlight.
    • By StreamZ
      I am in the process of slowly repairing everything on my 230 that had been bought from a farmer and obviously had no love ever in its life. Anyway, as I pull off one thing, fix it, reinstall it and then ride around again, I keep coming back to it not being the most aesthetically pleasing 230 on the planet. I was wondering if anyone has suggestions for sticker kits leave 'em below.
      FYI: I would like to keep it as stock looking as possible maybe even use the sticker kits from the last couple years of motorbike.
    • By Daniel627
      I hate finding awesome deals, but not able to make it happen!
      I found a complete '05 crf150f that I would love to get for the gf and get running. He wants $400 obo. It's a 7 hour drive though. I would have no problem making the drive normally, but even if he'd take $300-350, it would still cost me about $150 in gas. I can't really justify spending the money at this point in time and that sucks balls!
      I just had to rant for a moment
    • By Dumpdaveinfl
      Hey guys,
      Just  finished my xr and wanted to share some pictures with what I done. I have read a lot of posts on suspension for the xr, so I’ll share my mods.I got a set of dnm hornet forks from my wife on my birthday. With a new front I had to do a conversion on the back-so I went with a Crf150f swing arm that got off eBay. After some machine work in a Bridgeport mill removing 5/8 off each side it fit. I removed extra 1/4 inch to allow for chain alignment so it could be shimmed. The  frame was over drilled to 14mm and had to shorten the bolt by removing the bolt head and re-weld a nut to the stud. The shock is temporary until I figure linkage or direct mount but for now it’s a 11 inch fast ace 1100 lbs with adjustable rebound. Also for ease of service I drilled and taped the swinger and shock pivots with 6mm zerks. The wheels are the stock Crf150f and installed Ebc slotted brake pads.
      The DNM front forks were a challenge as no bearing combination would work with the 41mm race. I used a set of roller taper stock bearings and shimmed the bearing to the triple stem. Brake caliper had to be modified with a new bracket to use the 240 rotor. Also I have yet to find information to support these forks so if anyone has information on these please let me know..
      35inch seat height
      as for the rest of the build the motor has a engines only 120 kit with cam and slotted cam sprocket and mikuni tm24 carb. Shower head and oil pump by Daytona and alto red eagle clutch with bbr springs and a hydraulic clutch. Cdi and coil, new seals. installed a bbr  cradle with engines only aluminum front mounts. Had to remove 2mm off the engine and frame dowels to get these to work together. A new seat cover and foam with a clean up on the plastic. Let me know what you think. Thanks
