Suddenly wont start or idle
I recently found I had the Oil migration problem. Thaught I fixed it but installed the RT crank seal wrong.
At the same time the bike suddenly stopped starting. I was able to bump start it while bliping the throttle. It also dies at anything less than 1/4 throttle.
I am guessing that the Pilot Jet is clogged and this is my problem. I only had a quick chance to glance and the fuel screm was still in.
The rt crank seal was wadded/ ripped up pretty bad. Could the friction of the crank seal miss alligned rubbing on the beering have prevent the engine from spinning freely?
I guess I will know when I get it back together and check the Pilot Jet, but I can not check it for a few days...
