Cant find this oil leak !!
So my bike has developed this crazy oil leak(gearbox), I do not know where its coming from......I took the power valve cover off to see if the shaft seal had gone but there was no oil in there......but it would seem its the only place it could be coming from?
I want to change the seal anyway, is it pretty easy? Anyone done it...
Any Ideas ?
Nope its not plugged, are you thinking its two stroke or gearbox oil?
How easy is it to change the shaft seal? Do I need to split casings?
If you are talking about the lower shavt seal you have to drain tranny and coolant, remove exhaust(just to make it have more room) remove rear brake lever and then the right crank case cover, when that off remove the coverner from the case cover, remove 2 alen head screws from shaft, remove shaft and then replace seal. IF you are going to do the upper seal , remove linkage rod from power valve rod and try to pick out the seal from the cylinder and then slide the new one in.
thanks cookiemonster:thumbsup:
