DRZ 470 Jetting Question
OK, so finally I get to do my 470 conversion :thumbsup:
The output bearing collapsed - so that was the perfect opportunity for the upgrade.
Well - now comes the interesting part - the carb will be a bored to 42mm cvk carb, but b4 I install that I first want to make sure that the 470 conversion is running OK and run it in a bit.
So for the first while I want to use the std 36 BSR carb ..........
It is currently running a JD jet kit with a K&N air filter. Altitude is 5500 foot.
What would the reccomended jetting for the 470 be ?
