Lifan 150 oil?
Here in California...
Conventional Autozone brand 10W50 for summer (anytime it's not snowing) and 5W30 for the snow. Used it in all my china motors, changed it a 7-10 hours and ride on. -BIG DAN:thumbsup:
Thax bud!!
I was thinkin about using synthetic? The motor uses about half a quart of oil ?
Maybe it will help extend the life of the motor.
Falcon!!
Some say that sythetics are no good in china motors.
I believe that oil is oil.
I also believe that FREQUENT oil changes are the key with china motors. EXCESSIVE oil changes are where the extended life is at. Not oil type. Especially if it only holds a half quart.
If you ride 10 hours a week..
At $2 for a conventional change a week versus $8 a week with synthetic.
Life will be greatly lengthened if you use fresh oil everytime. Your money is your money. Ride Chinese! -BIG DAN:thumbsup:
Car oil isn't good for bike clutches. I always use an oil designed for heavy equipment, something like Mobil Delvac 1300, or Shell Rotella. Lots of zinc for the hard parts and bearings.
Good luck
I have not seen a difference in using "MOTOR" oil in a motor, and using desiel truck oil. I use Non-detergent 30 single viscosity. Changed so regularily it is always clean. You can use any brand you want. -BIG DAN:thumbsup:
Thax guys
Well I went with NAPA full Synthetic 10/30 $4 a quart at 2 oil changes per quart= $2 per change.
When it starts get hot here in the Cal desert I'll change to a little heavier waight.
Falcon!!
