04 KX250 2t, only 10 clicks avail?
So I am setting all of my clickers to baseline on my new, to me, used 04 KX250 and the manual says there is a range of 16 clicks available and std is ten out.
My forks rebound was screwed all the way in and there is only 10 clicks of range in the adjustment!
I set it at eight clicks out but I am worried that is two slower than stock and my goal was to be +2 for all to start as a trail bike setting and go from there, std 10 +2 would be twelve and my rebound clicker won't go out that for for some reason.
What do I do now?
What do I do now?
What have you done? Have you serviced the fork yourself? Your reb needle could be stucked. When turn the reb screw, how does it feel...stiff? Are the caps tighteded right on the cartridges?
