Clutch Issue
I have a 98 YZ 250 and the clutch lever quit working yesterday when riding. I bumpstarted the bike on a hill and just rode back to the truck in 1st gear. After I got home I started removing the cable from the arm on the engine case to check and make sure the cable hadn't just broken, which it was not broken. When pulling on the arm, it just came right out of the top of the case. What is the problem??? I am not sure how to tackle this one. Any advice would be helpful before I tear into the clutch??
My guess is that the shaft broke and only about half of it came out. Can you take a picture of the part that came out and post it? Someone here will be able to tell if it is broken.
There is a small allen screw that holds the lever in place so that it does not pop out, at least on the 00 and up models, should be the same.
Pull the clutch cover off and remove the 5 bolts for the pressure plate. Remove the pressure plate and you can leave the plates in or remove just a couple if they want to fall out. Remove the thrust bearing and the push rod, check that the push rod is ok. Now push the lever back in through the flywheel side, back into the case, it should just slide in at this point. Put the rod back in the same way and while holding the end with your finger, use your other hand and pull in the lever, the rod should extend outwards. If it does then the arm just popped out and it shouldn't be damaged.
If it does not then the clutch arm snapped and there's one piece in the case, and the other you can remove with your hand after your remove the flywheel.
Try that and we'll go from there
I'm looking at the parts diagram and I can't see a bolt that holds the lever in, you might be right in which the push rod does hold the arm in. The push rod may be worn down.
Pull the push rod out and take a look
It's most likely your pushrod that is causing the problem. I had this exact problem on a 96. Ask Roland he received alot of questions from me about it haha.
The part you pulled out is the push lever complete.
Well, I just tore into the clutch side and found the whole clutch plate assembly had come loose from the shaft. There is a nut with a special lock washer in the clutch plate assembly and it looks like someone who owned the bike before me had maybe put new clutch plates in it and put the nut back on and didn't bend the tabs back up on the lock washer to prevent the nut from spinning off. No broken parts, just retork the nut and lock it down and put it all back together and ride!!!! Thanks for the help
If you take a look at the fiche diagram below you can see the clutch arm (#24) is notched. Sometimes the edge of the notch wears out to the point that it will not catch the push rod (Part #23) I replaced mine when I did my restoration. I have not encountered an issue with the arm just pulling out of the case.
If you look closer at part #24, in the annotated fiche below, the notch in it should catch on the clutch push rod to prevent it from sliding completely out of the case.
Sounds like either the push rod, or the clutch arm, or BOTH parts are worn enough to allow it to slip out.
I recommend replacing both parts, the bearing and seal on the clutch arm side, and add a 2mm valve shim from a YZ250F to make the clutch pull easier. You put it into the cup (Part #19) then insert the clutch push rod as you are reassembling the bike after replacing the parts above
Thanks for that tip goes to RCANNON. Made a HUGE difference in clutch action on my 98YZ
To expand a bit on my (well, RCANNON's tip)
Look at part #14 on the fiche below. Pick up the smallest one, a medium one, and a large one. Install the medium one and, if you like the easier action it provides, use it. If you want more, use the bigger one and, if you want less, use the smaller one.
I used the 2.4mm part from the TT Store and it makes the clutch action silky smooth
Yes, the push rod does retain the clutch arm on the stator side, but on mine, since the nut #18 that holds the clutch basket in had come loose, it created extra play for the push rod, so it let the clutch arm just pull out. I retorked the nut and folded the tab on the lock washer and its working like new again.
  • Similar Content
    • By Lone Danger
      Ok so I'm looking for opinions from those who have been on yz125s and 150 exc/xcw's and maybe the ktm 200's exc/xcw's. You gotta be out there.
      Here's the deal...I'm 5'7" 165lbs. A couple years back I was looking for a small bike for my wife to learn on and for me to play around with and race. Could only afford one bike. I got a '09 ktm 105 sx. Once I got it sprung for my weight it was great. I have been top five consistently in my local harescrambles B class, believe it or not. Ya, you were not the only ones shocked. And did pretty good in the local mx races as well, junior class up here in Canada. Lack of power was sometimes an issue but I learned to deal with it and just scream, scream, scream!
      However my wife is a complete beginner and she is scared of it. I have since moved her to a 4 stroke.
      Just got a mint '01 yz15 mid summer. Like less than 200 hrs! I have absolutely loved it on the mx track. Suspension is perfect and I love the extra power. I had planned to set it up for woods/mx with a suspension revalve. However, did a harescramble race a month ago that was really technical. Granted I have not done anything to the suspension minus clickers, had too much psi in the tires (13 front and 15 rear) (yes I know that's wonkey, I only had time to get a heavy duty tube in the front and had a stock tube in back. Less psi in the back would have been instant pinch flat because its so rocky) and it was running rich. I had to scream the thing to keep it running and even changed a plug mid race. Well I'm sure you can guess but it was the worst experience I have ever had on a motorcycle. The more open sections I passed a lot of people but the tech sections required way more effort than I liked and the suspension beat the hell out of me!!! Like my knees, wrists, and shoulders were just done. (I was out there for three hours).
      So keep in mind that I just came off a 105sx with suspension mods (set up for woods/mx). I have no problem slipping clutch and shifting precisely, yatta yatta. (I don't think the 105 would have done well here either due to even less power, however...) I've been second guessing fixing this 125 up for woods ever since I rode a friends '09 ktm 250xcw. I rode it on a local mx track. The power was just so effortless and I was absolutely floored by how the suspension worked. I never thought that I could hit the woops that hard and clear every jump on the track on an xcw and feel THAT good! It felt a lot heavier though, and I think the price tag on these things are going to be a stretch.
      So here's my question. I want the lightness of a 125, but want to be able to race both woods and mx. How does a 150 exc/xcw ENGINE compare to an mx 125 engine? I love the 125 engine, but more low end would be usefull in tech areas. But if there is not a huge difference, I will probably just revalve the yz for woods and go tubless, etc. The 150exc's are so expensive and I hardly ever even see one for sale unless its brand new. I don't want the weight of a 200/250/300. I barely touch the ground on a 125....so it has to at least be light. Is it worth waiting for a 150 engine? Thanks guys.
    • By doolan
      Hi guys I have a 2018 yz250 looking at changing springs front and rear I'm 200 pound ride b class moto.
      Having problems choosing spring weights using the calculators as mx tech say I need .45 fork springs and 5.2 rear but racetech say .48kg forks and 5.8kg rear.
      What are other bigger guys
    • By YamahaYz1
      Hey TT, I know there's endless topics on YZ250/ two stroke tuning in general but I have not been able to find one that helps me get my 09 YZ250 set up for my riding style and where I ride so I'm here asking for help. I got this bike around 1.5 years ago and have not known how to set it up properly. I know no one can give me a perfect set up but I'd like a good starting setup to work from and tweak to perfection. Throughout this time I've had this bike, its always been covering the bottom of the entire silencer and dripping all over the swing arm and rims with oil. Also, the joint between silencer and expansion pipe has oil around it too but I've heard I have to close the gap a little to squeeze the silencer a little tighter and stop the leakage there. I don't have too much experience messing with carbs but I've messed around with previous two strokes and tuned them a little better. I change the oil on my bike after 15-20 hours on it and clean and oil the air filter after almost every ride. The sparkplugs never last me more than a few months but recently have been lasting me no more than a few weeks. With the excess oil from the pipe and spark plug fouling you can see why I need to set my bike up to stop this.
      The bike:
      Completely stock with V-Force 3 Reeds and a FMF Shorty silencer.
      Usually running around 32:1 premix with 91 pump fuel because I prefer to keep it well lubricated instead of running rich.
      Riding:
      I ride enduro in Ontario, Canada. So mostly single track and some fire roads but nothing close to MX and not a lot of time wide open. Therefore, probably mostly 1/4-1/2 or 1/4-3/4 throttle range.
      Where I ride:
      Usually 0-500' above sea level. With temperatures ranging from around 15-35 degrees Celsius (55-95 Fahrenheit).
      If anyone can give me a setup to go from, that would be very much appreciated. Even multiple set ups for different temperature ranges or any suggestions would be much appreciated. Thanks and sorry for the long read, I just didn't want to leave anything out. Ask any questions if you have any, too.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
