Hey, on my 2000 rm 80 Im getting some "spooge"/leak out of my exhaust where it meets the engine to the point were it is getting the back side of my front fender black.....bad seal? Or maybe mixing ratio or somethin? Help!:thumbsup: Who is the culprit?
I am guessing this is not an all out race machine judging by the year of it. A little too much oil in the fuel is not a bad thing, it will help with the longevity of the engine. The spooge you are seeing is incomplete combustion related, no big deal. It will lead to excessive build up if not cleaned regularly. For top performance you want the engine to burn as clean as possible but that also shortens the life of the engine.
In order to not see the spooge on the fender I would guess a new head pipe gasket will fix your problem, possible new springs also.
awesome, ill order the gasket and maybe change my pre mix just slightly and see how it goes. Thanks alot!! :thumbsup:
