Dr350 Binkers
Does anybody have a diagram of how to put blinkers onto my dr350?
I just bought blinkers all around and a taillight for my bike
I have the turn signal buttons on my handle bar.
Where is my flasher relay supposed to be located?
If its the S model its in front of the headlights in a bundle
my bike is an S model but the harness is really hacked up. I don't currently have a battery or an ignition. Its hardwired on. If I had a battery I would have to get an ignition or on/off switch so the battery doesnt drain right?
This is the rear section of my harness.
Do I need a flasher relay of some sort? I haven't seen one on my bike...
Heres an early wiring diagram. Should be fine for newer bikes minus the electric start wiring.
If you save the pic to your pc you can zoom in on it.
The flasher should be under the front cowl on the left side of the headlight. Black square unit mounted in a rubber retainer.
The flasher (turn signal relay) may very well be bad. You can substitute a heavy duty automotive flasher (round shape) from any auto parts store for $5 vs the $45 Suzuki is going to screw you for. :thumbsup:
1990dr250sWiring.jpg?t=1267715058
EDIT*
Found a 93-94 diagram as well.
DR350Wiring.jpg?t=1267715918
