Factory mods
How did Suzuki increase the HP from DRZ 400s 2000 (32HP), 2003 (39 HP), to 48 HP in the later years? They all had the same engine right?
where did you get those numbers?
sorry, I must have missread. Do all the years have the same HP?
Correct me f I'm wrong but believe the earlier dirt only drz'S had more HP but also had a better carb/cams and a slightly larger heap pipe. And I think some of I changed around 2003??
Cam changes in the later years increased power, keep in mind that these are flywheel horsepower ratings with free flowing exhaust-they do not take in account 20% drivetrain loss.
Some information for you...
Suzuki DR-Z400 model history
2003—
2003 Suzuki year code: K5
Four-stroke. Three different models; the DR-Z400 with a kick start, the DR-Z400E with an electric starter and the road legal DR-Z400S with lights, flashers, mirrors and smoother tyres for road use.
DR-Z 400 2003
Overall Length: 2,235 mm (88.0 in)
Overall Width: 825 mm (32.5 in)
Overall Height: 1,235 mm (48.8 in)
Seat height: 945 mm (37.0 in)
Ground Clearance: 325 mm (12.8 in)
Wheelbase: 1,475 mm (58.0 in)
Dry Weight: 119 kg (262 lbs)
Engine type: Water-cooled 398 cc DOHC 1-cylinder, 4 valves. 48 hp (35 kW)/ 9,000 rpm, 41 Nm/ 7,500 rpm.
DR-Z 400 E 2003
DR-Z 400 S 2003
Overall Length: 2,310 mm (90.9 in)
Overall Width: 875 mm (34.4 in)
Overall Height: 1,245 mm (49.0 in)
Seat Height: 935 mm (36.8 in)
Ground Clearance: 300 mm (11.8 in)
Wheelbase: 1,485 mm (58.4 in)
Dry Weight: 133 kg (293 lbs)
Engine type: Water-cooled 398 cc DOHC 1-cylinder, 4 valves. 40 hp (30 kW)/ 7,600 rpm, 39 Nm/ 6,600 rpm.
DR-Z 400 S 2003
2004 Suzuki year code: K5
DR-Z 400 E 2004
DR-Z 400 S 2004
DR-Z 400 S 2004
2005 Suzuki year code: K5
A Super-Motard version of the DR-Z400S, shod with wide, 17-inch radial tyres, black aluminium rims and large diameter disc brakes, was released for the 2005. The model was called DR-Z400SM.
DR-Z 400 E 2005
DR-Z 400 E 2005
DR-Z 400 S 2005
DR-Z 400 S 2005
DR-Z 400 SM 2006
2005 DR-Z400 specifications
Engine type: liquid-cooled 1-cylinder 4-stroke, DOHC, 4-valve
Cylinder displacement: 449cc
Bore x stroke: 95,5 x 62,8 mm
Compression ratio: 11,9 : 1
Carburetor: Keihin FCR40MX
Lubrication: Semi-dry sump (SASS)
Ignition: Digital AC-CDI
Transmission: 5-speed constant mesh
Final drive: chain
Rake/trail: 25,5° 30' / 108 mm (4.25 in)
Front suspension: Kayaba 48mm telescopic, cartridge-type,
22 compression & rebound settings
Front suspension stroke: 310 mm (12.2 in.)
Rear suspension: Link-type, fully-adjustable spring preload,
16-way compression & 19-way rebound damping
Rear suspension travel: 310 mm (12.2 in.)
Front brake: Single hydraulic disc, 2-piston caliper
Rear brake: Single hydraulic disc, 1-piston caliper
Front tyre dimension: 90/100-21
Rear tyre dimension: 120/80-19
Fuel tank capacity: 7,0 liter incl.reserve (1.8/1.5 US/UK gal.)
Color: YU1: Champion Yellow No. 2
2006 Suzuki year code: K6
DR-Z 400 S 2006
DR-Z 400 SM 2006
DR-Z 400 SM 2006
2007 Suzuki year code: K7
The DR-Z400S offers the following features (basic differences from DR-Z400E):
• Compact digital instrument cluster with speedometer, odometer, twin-trip meters with addition/subtraction capability, clock, timer and stopwatch functions
• Smooth throttle response with a MikuniT BSR36 CV-type carburetor fed by 6-liter airbox. • The left side cover has quick-release fasteners for easy access to the air filter
• Reduced compression ratio (12.2:1 to 11.3:1) for operation with 87-octane fuel
• On-road legal lighting with bright 60/55 watt halogen headlight, compact tail/stoplight, lightweight, rubber-mounted turn signals and horn
• Thermostatically-controlled cooling fan mounted to the left radiator helps maintain consistent operating temperature in traffic
New Features for the 2007 DR-Z400SM (Super Motard): Renthal tapered aluminum handlebar for reduced vibration and aggressive new look, new front and rear axle sliders.
2007 DR-Z400S K7 colors: Yellow, Blue
2007 DR-Z400SM K7 colors: Yellow, Black
DR-Z 400 S 2007
Overall Height: 1,230 mm (48.4 in)
Dry Weight: 132kg (291 lbs)
DR-Z 400 S 2007
DR-Z 400 SM 2007
Overall Length: 2,225 mm (87.6 in)
Overall Width: 855 mm (33.7 in)
Overall Height: 1,200 mm (47.2 in)
Seat Height: 890 mm (35.0 in)
Ground Clearance: 260 mm (10.2 in)
Wheelbase: 1,460 mm (57.5 in)
Dry Weight: 134 kg (295 lbs)
DR-Z 400 SM 2007
thanks for the scoops! I am looking at buying a 2001 400s low miles great shape and wondering how to increase the hp from 32 to 48 like the newer ones.
Don't go by Suzuki published h.p. numbers, they are at the crank which is pretty much meaningless. We go by what power the bike puts to the ground. A stock S makes about 32 h.p. out of the box and a stock E makes about 40 h.p.
To make 48 h.p. at the wheels on an S/SM will require cams, a carb, 3x3 mod, big bore kit and one of two exhausts.
thanks to all of the DRZ gurus who responded. I hope to join your ranks as a junior member soon. Aloha Andrew
I really don't know where those numbers are coming from but I think they are wrong.
Unless the the S or SM started shipping with the 39mm FCR, uprated cams and exhaust from 2005 onwards then no way was it making 48hp. As far as I was aware there hasn't yet been an S or SM which was shipped as standard with E or K engine spec.
Even in the description it states that the SM has the BSR carb - nope, I'm calling BS on this one. :-)
I'm with Rich, those figs show the 2005 E and S having the same power so however its measured its wrong, they're not the same
Dan
I don't know where you got that info, but a quick look at the weights shows it is wrong. The SM is 30 lbslighter than an S?!?! and the E and Kicker models were the exact same weight?!?!
where are you in hawaii man? I should have my bike back together next weekend.I live on the windward side of oahu. PM me when you get it and we will go ride. I got a couple guys I ride with. 2 drzs and a few ktms.
48 hp stock :thumbsup:
