05 crf 250r takes 1/2 hour to start
Current set up
je piston
hot cam
full yosh exhaust
boyseen quickshot
ap o-ring mod
intake valve .004
exhaust valve .010
Flat part of slide down
175 main
42 pilot
jd blue needle 5th position from top
pilot screw 2 out
Riding between 0-1000ft about 45*f
The bike will not even try to start with the choke on. When it finally starts without the choke I can pull it and the bike will idle up like normal.
The pilot screw has little to no effect unless closed all the way. I have this one. http://www.jdjetting.com/xcart/product.php?productid=85&cat=4&page=1 Not sure if it is the right one. The o-ring is not up in the carb.
Once started The bike runs good with a little bog out of really tight corners. It will restart with one kick after hot. I do not use the hot start lever at all.
Thanks for the help. I am stumped because it runs so well after the fisrt start of the day.
