2005 TTR 90 Hard Start (Florida)
Hello Everyone I pulled my sons old 2005 TTR90 out of the barn to get running for my nephew he is tall enough now for it. It has been sitting for a while so I pulled the carb and cleaned it out put it back together thing wont start without starter fluid. It runs and idles fine does back fire a little when you let the throttle go may be a little lean. But it just wont start with out the starter fluid any ideas where to look.
Thank you for any answers!!!
Dump the old gas and pull the carb and give it a good cleaning, especially the jets. Also, wouldn't hurt to check the clearance on the valves and clean and lube the choke cable.
On top of that, change the oil, clean/oil the air filter and install a new plug.
