125 fuel screw problem
we all know how fun these carbs are, but just when it get it idling right and starting easy the fuel screw vibrates it's way almost all the way out and wont idle or even start. i'm just going to torque strip it to keep it in place.But i dont get it, shouldn't it idle high when the screw is further out.
has anyone else had this problem. also, how many turns from bottom are you guys running on your idle and fuel screw. i think mine were at about 2.5 each but not sure.
The idle screw and fuel/air screws are different. So the fuel/air screw adjustment wont affect the idle. I have never had your problem but I would replace the screw. See the cool ones that are in the parts store on this site. Also go to the sticky at the top of this forum for your settings. Very informative and spot on.
the parts store here is a little to corn-fusing for me. i found one on ebay but i dont like to order stuff online. i'm going to check out the local shop this saturday. but i think it's not idling/starting because it's getting way too much fuel.
35 Ki you need to check the sticky! I think you need to start at 1 1/2 turns on the screw. Have you ever done any carb work to the bike?
yeah i done pretty much all the free diy mods and re-jetted the carb from the sticky. i was just trying to see if others have had this issue.
There are two types of screws for 0-1/4 jetting on a carb, fuel and air screws. Air screws are on two stroke engines, they allow an adjustable amount of air into the system. Turning the screw in will richen the mixture, turning it out will lean it. Richening the mixture will drop idle speed, while leaning it out will increase it.
This is the opposite for four strokes, such as your bike, that use a fuel screw.
I have had the issue. But here in california it may be a little different. Of course its cold blooded so if its been cold I would try and kick it a bunch before hitting the magic button. My problem was bad gas. I changed it and it fired up and ran great. The jets can get clogged in just a month or so and if the weather has been real cold then it may happen quicker.
Not necessarily true. Some 4-stroke carbs use a air screw, like my Kitaco Mikuni VM26 carb. You could say it's a modified 2-stroke carb and I won't argue that, but it's a four stoke carb now.... and rips. Basically, if the screw is behind the slide it's a air screw and if it's in front it's a fuel screw.
