2004 kx85
ok I am doing a complete topend replated cyl. wesco top end this is a new bike I got for my son so I have very littil history on it !!the bike does have very few hours on it (just from the looks of the bike)
i have been going over this bike from one end to the other, we race so I need it to be right but with all this talk about the kips I have checked the alignment of the shaft and all is good there but I did see there is a littil movement in the shaft not side to side but it will twist a littil not much about a 16th or less is this normal!!
also I know this is a loaded question but what is the right way to brake in a new pistion and cyl.
thanks mike
Yes, it's normal for the shaft to "twist" a little.
As fr break in, 200 is right. But I suggest a heat and cool method on the stand. Allow to run, easily throttling it up slightly till the cylinder is just hot enough to not touch. I do this 2 or 3 times, depending on when I'm doing it. Then ride it easy for a few minutes, getting on the pipe here and there. Let cool. Then be sure to properly warm it up from there on out.
The other situation I was referring to was between heats. LOL put it in, start it up, warm it up, Race it. Believce it or not, never had a failure yet.
Edited by SAPPERS
thanks guys it sucks to be 35 years old and still can't spell or explain what i am asking!!!
If you're having that much trouble, PM me and I'll give you my ph#.
thanks but I think i have it going now but I might take you up on it latter
  • Similar Content
    • By jace kornegay
      I have a problem with my stage 2 exhaust cam on my rmz whenever I kick it over the exhaust cam likes to stop at the lift unless I put it at tdc or kick it really slow it runs fine when it starts and I have played around with the shims right now all the valves are shimed and I have checked the timing everything’s to spec it just gets stuck at the exhuast I’m pretty sure it’s something to do with too much compression I probally will end upbuying stock cams but wanted to see if anyone knows how to fix this first
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By 2strokeKyle
      I am wondering how a kx125 will do at at Glaims. I am 14 years old 5 foot 4 inches  and 100 pounds. I will have a paddle tyre in the back too.
    • By Snox90
      will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
    • By Kaelan Frost
      I have a new cylinder that i bought to rebuild my 1993 kawasaki kx250 with, because the old cylinder was destroyed. The guy said the cylinder is overbored a little but never gave us numbers. The new one i bought came with a piston thats been used and i would like to replace. I believe the piston that came with the cylinder is the correct size, but it very well could be off and i have no way of knowing. So how do i properly measure the cylinder bore, and how do i use this measurement to find what size piston I need to get?
      thanks,
      Kaelan
