KDX chain
just picked up a nice 96 kdx 200. i saw that the chain on the bike was wearing oddly- the sides where all shiney and worn down. after taking the chain off i see that it has been rubbing on the case!
the chain is not even streched, its just baddly worn on the sides. i dont trust it and i dont want it to rub on the case. can i order a new o-ring chain for my bike and not have this problem?
Rubbing on the case? How is this possible? There would have to be some issue with the counter shaft. Usually the chain will rub on the rear chain guide a bit, causing some wear to the sides of the chain. On your bike the guide is for a standard chain, so an o-ring chain will rub even more if it's not clearanced or changed out for an FRP or kdx220 guide.
Ya something fishy is going on here. Rubbing the case means something is up bigtime.
if i get some time with a camera in the next few days i will post some pics. temps have been in the 20's so im not too exited about going to a nice cold garage lol.
i can see the rear sprocket to the front sprocket is lined up strait, and the swing arm slider is wearing evenly and strait
foe all you guys that call me crazy, some pictures. its a 520HV oring chain. its slightly wider than 3/4inch, this was why it was hitting the case.
i apologize for the poor quality pictures, all i had was a cell phone cam.
Does the collar behind the sprocket, that goes into the case, look worn, or any form of buggered up? From my manual blow up picture, that looks to be what regulates how far on the sprocket goes, other than the end of the spline teeth.
Does the sprocket move in and out very much on the shaft while the circlip is on, and everything is as it is being ran?
That's right, there's just the collar, then sprocket, then the snap ring. I'm willing to bed that collar is missing or something.
the chain is/was the problem. it was an HV520 motorcycle chain- WAY to thick for a dirtbike. the collar and output shaft have no play in them, and they align straight with the rear sprocket.
i picked up a new standard chain yesterday, and it fits perfectly. i think it was a case of a backyard mechanic trying to be cheap and fit a motorcycle chain on a dirtbike.
thanks for all the help
A dirt bike isn't a motorcycle?
I still say something is wrong. A 520 o-ring chain will easily clear the case on a KDX.
its not a street bike that requires a chain to withstand 100+hp at the rear wheel no. street bike chains can have thicker plates on the links-this accounts for the chain being much wider than a NORMAL 520 chain.
  • Similar Content
    • By jace kornegay
      I have a problem with my stage 2 exhaust cam on my rmz whenever I kick it over the exhaust cam likes to stop at the lift unless I put it at tdc or kick it really slow it runs fine when it starts and I have played around with the shims right now all the valves are shimed and I have checked the timing everything’s to spec it just gets stuck at the exhuast I’m pretty sure it’s something to do with too much compression I probally will end upbuying stock cams but wanted to see if anyone knows how to fix this first
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By 2strokeKyle
      I am wondering how a kx125 will do at at Glaims. I am 14 years old 5 foot 4 inches  and 100 pounds. I will have a paddle tyre in the back too.
    • By Snox90
      will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
    • By Kaelan Frost
      I have a new cylinder that i bought to rebuild my 1993 kawasaki kx250 with, because the old cylinder was destroyed. The guy said the cylinder is overbored a little but never gave us numbers. The new one i bought came with a piston thats been used and i would like to replace. I believe the piston that came with the cylinder is the correct size, but it very well could be off and i have no way of knowing. So how do i properly measure the cylinder bore, and how do i use this measurement to find what size piston I need to get?
      thanks,
      Kaelan
