Best fat bar bend for a shorter rider
Hey Guys,
I did a bunch of searches for bar recommendations but mostly what I found was info from taller riders. I'm 5' 7" and looking for some fat bars. I'm looking at pro-tapers primarily. Any shorter riders have recommendations?
Thanks, Will
5'6" here, mostly fast trails and single track. About 50 /50 seated and stand up riding. I use the CR-Hi Pro Taper.. DRZ, RM250, CR125.. Just installed a new pair on the RM this morning....
Anyone one want a 2 week old Pro Taper Yamaha Yz bend bar? Only used once, of course that was the ride I threw the RM to the ground...so these bars make great left hand turns... but going straight is not so easy... :thumbsup:
Henry/Reeds are pretty low. I added them when I went to GPR undermount and risers. Now I wish I had gone with CR High b/c the reeds are too low. Wanna trade? See my garage.
Thanks for the offer, but a friend of mine bought a bunch of new Contours for 45.00 at a bike swap meet and he 's going to sell me a pair. He has Reeds, Windhams and CR high.
I just need to decide between these three now. I'm going to use a Zeta clamp too so I could always get some adjustment there if need be.
Just comparing the differences between the three bends and they are all within 1/4" of each other in height and sweep. Is this even enough to tell the difference?
I'm thinking any of the bars will be fine when they are that close. What do you guys think?
I second on the carmichaels. The carmichaels high are to tall for me. So the standard are a good fit.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
