New XTRIG pre-load adjustor
Okay...so we've been doing some testing on these over the last few weeks and all is going well...so we're going to start carrying them.
Price to TT members is $134.95. Regular retail is $149.95.
There are three models (more coming soon).
1. 06 to 09 YZs and 2010 125/250F/250
2. 09-10 KX450F
3. 09-10 CRF450R
Here are my good and bad thoughts on the product.
The good:
1. You can remove the existing metal and aluminum rings.
2. Unlike the Merge unit, the range is limitless. You can run this up and down the entire shock. Why? This is a worm drive, verses the hydraulic means of the Merge unit.
3. Changing the sag is as easy as changing clicker settings.
4. Unit is still tucked away so there's little worry about it getting damaged in a crash.
5. It's trick and well made.
6. Works with most spring bearings.
7. You'll pay more attention to fine tuning your shock sag and that may have some benefits such as more speed and control.
8. You can adjust the sag even when you're sitting on the bike, or when you're out on the trail.
9. German engineering. Very well made.
The bad:
1. It cost money.
2. It's one more thing that could break.
3. You can't move it over to your 2010 YZ450F.
4. It takes A LOT of turns to get it to move just a few millimeters. This could be a good thing for really fine tuning things, but sometimes you just want a power drill to get it over with, (it's a worm gear, with a very high ratio).
5. It will most likely not match your other bling.
6. For most of us, we set our sag once and then ride the bike to the coffin.
Here are some photos.
Real cool idea...honestly I don't think I change my sag enough to really fork out the money :thumbsup:
Nonetheless, very sweet.
I've got one on my 09 CRF 450 and basically have no gripes, except that you need a wrench with a joint since a straight wrench will not reach to the adjuster. The subframe is in the way. Since I have the stock spring and use preload in the common range (less than 10mm) it kind of makes the adjuster superfluous. As Dave pointed out you need lots of turns (I think 24!!!) on the adjuster for one turn on the spring preload. This makes adjusting without a T-handle or electric drill basically impossible. So if you use the stock spring or one of the same length save your money!
Michael
I would like one of these for an A-kit Showa shock. Could be same as standard "CRF" shock's unit, but I don't know. Anything in the works? no pun intended.
I've been using one of these for several months, and it's worked great so far. I like it because even though I don't reset the sag a lot, I do sometimes want to mess with it a little, and this makes it much simpler. I have it on my '06 YZ450, and while a wrench with a swivel joint does make it simpler, I is possible with an unmodified MP T-handle, too. By the look of the illustration, I think they've extended the drive screw, and it should be easier to reach without interference.
It's a 24:1 ratio, so it does take that many turns to spin the collar one turn, but how often do you change it more than two full turns in either direction? Even at that, it's much simpler, actually faster, and certainly less brutal, than breaking lock rings loose, etc.
I like it.
I think that most of us do not set our preload as close as we should, with this little chestnut there's no more excuses. How ever, $150 is on the high side.
Dave, do you have one of these that would fit a Showa shock? '05 CRF250X to be specific. :thumbsup:
We don't carry the SHOWA units, but XTRIG does have an 06 and up unit on their website.
I assume that means it won't fit the 05 unless they just decided not to validate it back that far.
We can always check, or perhaps one of the German dealers can help out.
The '05 Showa is the same as the '06-'09 as near as I can tell. Same shock body at least.
I spent a good chunk of my afternoon trying to find a U.S. source to buy one of these and was coming up dry, so I was excited to see that you were carrying them. Any chance you can GET a Showa version? :thumbsup: Thanks Dave.
Looking to get one of these for a 2010 YZ 450, any idea when it might be available?
Don't know yet, but I should know in the next day or two. :smirk:
Sorry for the delay.
Dave
Will have them this Wednesday.
$139
how do i buy x-trig products here in the U.S.?........i am interested in this, and also some of their clamps and bar mounts
We have most of the XTRIG items in stock so just let me know what you need.
This exactly what I have been looking for! I won't get my hopes up yet, but what are the chances of them having/ making one to fit a WP shock on a KTM 690r/e/smc? I know it is an odd ball applictaion, especially with the horizontal reservoir, but I need something different in there as the stock aluminum ring deformed the first time I put a spanner on it and I do not want to have to deal with that headache ever again!
Does the universal fit version fit a 2006 YZ250 (2-stroke)?
Thanks!
....nevermind....found the answer and ordered one cheaper elsewhere.
Edited by andrzej
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By hondahondo
      A few picks of my winter project.
    • By Luke Hufford
      Hey guys. I recently purchased a 16 yz250x and the first 2 rides i LOVED the suspension. Then the day before a race i reset all my clickers to stock and everything felt like crap. No plushness at all and deflected off everything. I now have a 5.4 shock spring for my 190 pound weight and dialed in sag. Any recommendations on where i should go from here? Right now the fork is 12 out on comp and 15 out on rebound. Shock is 1.75 turns out on hsc, 14 out on lsc, and 18 out on rebound. Any help would be appreciated!
    • By jake gu
      Today we’re going to be talking a little bit about automotive suspensions and how they work to smoothen the ride of your car. There are mainly three purposes of the automotive suspension system. First, they support the  weight of the vehicle. Second, they maintain accurate tire contact with the ground. And third, they absorb any shock that you get through the road when you hit a bump.
      Most modern vehicles come with an independent front suspension. Which means if one wheel hits a bump it does not disturb the other wheel. Nowadays, people use Coil Spring to support the majority of weight in the car. As it has a really good characteristics for absorbing any bumps as you go up and down on the road.
      However Springs aren’t very good at dissipating that energy. In fact that’s why you have the shock absorber. Which is there to smoothen out the ride and make sure the tire maintains contact with the road.
      In modern passenger vehicles the two most popular suspensions are McPherson strut and double wishbone style of suspension. The main advantage of the McPherson strut suspension is that it’s really cheap and simple that’s why a lot of manufacturers are moving towards this design. The double wishbone design allows the wheel to stay perpendicular to the body as it navigates a corner or as it goes over a bump. And that maintains good tire contact patch no matter where the wheel is situated. Another advantage of this design is that it can be made adjustable where you can control the position of upper control arms ball Joints.
      Click to Know More About Ball Joints and other Suspension Components
