ok, what now,
right, have 3x3, k&n filter, f2dogs jetted carb and a slip on of dubious origin,
It goes like stink but on the overun pops and bangs embarrasingly, even when i blip it it's the same, please say i haven't gotta take the carb off again.
sounds like an air leak somewhere. Check the rubbers to and from the carb ,and check if there's a leak in the exhausts port of the cylinder top.
i tried spraying carb cleaner on it while it's idling to see if it would change, no difference so i don't think it's sucking air from the manifold,
Some decel popping is usual, have you posted your jetting on the jetting forum?
Dan
Hi Dan, it's more than popping, it's exploding like a vintage car, hehe, it ran ok on f2's bike, i guess i gotta take the carb off again and clean everything, the bike's like new so it's almost certainly carburation.
What size of jets have you got in there ??? Excessive popping is commonly a very lean mixture.
Are you header and gasket in good shape ? Leaks there make it noise too.
Edited by tedmagnum
not sure what you mean by headers.
Well, in a single it is just one "header"
The "header pipe" is the exhaust pipe that fits into your engine head. Its held with 2 bolts which compresses a soft metal ring or gasket to form an airtight seal.
It could be leaking badly which would explain the excessive banging.
You put another persons carb on without making sure the jetting was right for you application? Jetting is almost certain to be your issue.
It has a Dynojet stg.2 jetkit.
Don't remember ,but the main is 155-160 ,and it's dj needle in it.
Ran great on mine, yoshi rs3 and a athena bb (could be lean on a std. bore) ??
Well i'm sea level in asia, the only jets i have are the ones in the carb from f2, or the standard ones, maybe i'll just ignore it, i get stared at all the time anyway so it's no big deal,
  • Similar Content
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
    • By 4strokeOnly
      My bike was stolen, so I'm liquidating my spare parts.
      I took this off my S and replaced it with an SM unit so my speed would be more accurate with the street wheel setup.  I no longer need this spare.  I greased it regularly and it was in good working order when I removed it.  Included is only what is pictured.  Cable not included.
      Suzuki part number:  54600-29F00
      buyer pays shipping.
