gearing question
How many teeth can you go to on the rear before you need a different chain? I did drop the front sprocket but it made no difference..
Thanks, Mike
Thanks, Mike
15/44 is at about 0.3 on the adjuster for me.
15/45 would probably need 112 links.
Jesse sells a 45t that can be run with the stock chain and a 14t up front. Any bigger and you have to add links.
I dont know if chain size makes a difference. i went to 520.
running 14/46 and had to go to 112 links
renthal front sprocket #R25252014
Purely the width of the chain.
I have used the following combinations with a new stock length chain.
15/44 15/47 14/47
15/47? At 14/45 and a 130/90-17 K-760 I can barely give the chain the proper slack. Did you have to get a different chain guide?
I was referring to the DRZ 400. Are we are talking about a drz 400 or another dr ?
