DGM needle
Hi! Anyone knows if a DGM needle for a Pwk carb can be found at Yamaha ,Suzuki or Kawazaki dealers as an O.E.M.? Thanx Johan!
Yes i know but there aint no sudco dealer in Sweden. I know Honda have them but i just checking some options. Thanx
True. I posted the "R1471N" OEM conversion in case you didn't have the info. I'm not exactly psychic as to what your particular situation might be.
I have put a PWK35 from a Kx125-90 on my Atc250 trike. Running DGJ #2 from top, 35 pilot and 142 main with 17mm float height. Iam still rich on idle and just of idle otherwise right on spot. I figured a DGM would lean it out on the pilotcircuit. The DGM is 3 steps leaner on the straight diameter.
