Carb replacemnt questions.
I have an 01 250f took it to the shop to get it to idle . Long story short I have to replace the carb and need to know if there is any difference in the wr carbs from 02 . could buy an 01 250f carb for $255,or an 02 wr for $109. need advice badly. The 01 has an oring issue thats not serviceable the 02 doesn't have that problem. Im do not race and never intend to race.
In one of the stickys it says all parts are interchangeable . so am I understanding an 03 carb will bolt right up to an 01 bike??
Any of the carbs will be fine. The oring is replacable (float needle valve seat) by a skilled wrench.
More concern is the wear of the carb body where the slide rides. You need to see the depth of the grooves from the slide wheels.
Its not the float bowl gasket but the one directly under the accelerator pump. the rebuild kit for the accelerator pump does not have this gaskets for the 01 carbs.
