Need More Low Speed....Please help
I need some more low speed dampening. If I pull my shock and forks apart would you guys be able you help me order the right shims and the order to put them back.
2002 XR400
Race Tech Gold Valves
Race Tech Springs (For my weight)
High speed is good
Rebound is good
Low Speed to soft
Thanks
Bob
I usually try thicker fluid...
My buddy has an older XR400 and i realized that the bushing around the cart shaft was dead, allowing massive bleed through around the shaft instead of forcing it through the proper bleed/piston/shimstack.
