fouling plugs what do think?
1982RM250 well the jetting couldnt get any more perfect last year. but i did a full rebuild on it and now it is a little rich. But the clutch side crank seal was the correct size double lip seal(not motorcycle specific). i am thinking the seal i bought is just not up to standards of a motorcycle specific seal. it went in fine, but may be a couple thousanths out of square. and my spark is not as hot as it should be' but the same as last year. it fouls plugs in about 5 minutes now and smokes with a sweet smell(not really bad). I already ordered a new oem seal for it. second opinions?? thanks
i am thinking its the crank seal. i just bought the correct size from a seal manufacturer, not from a bike parts store.
that an interesting thought. i have had the crank seal problem so many time. but that makes sense. i wonder wich spot would be leaking. i did use some gasket sealer on the middle case gasket. ill look into that. thanks
well i figured out i was just seeing the last leg of my cdi and stator going out. now their is no spark. no wonder it was acting all weird. the cdi has the red wire grounding on the inside. and their is zero resistance any way i test the stator. i have an older suzuki cdi, same wire set up, and the red wire is not soposed to be grounded.
