Changing premix during rebuild
I'm going to switch from castor 927 to HP2 this time around. My top end is off and I can look down between my crank halves and see a nice residual oil level in my bottom end. Should I try and get it out of there somehow and replace it with the new premix I'll be using or just not worry about it?
thats what castor does, leaves a thin coat of oil residue, i would leave it, no big deal
I personally would remove it in the interest of cleanliness. Once removed, replace it with a little of the new flavor and drive on. I am a clean freak when doing internal engine work, so that is just part of my routine. It's probably not neccessary and wont affect anything either way, but just an old habit for me. Good luck!!!!
Don't do it! I did that over a year ago and in a recent tear down it was the most measured wear of any oil I have ever used was with the HP2.
Stick with the 927 or the K2. The K2 is an excellent 2 stroke oil and never wore out my top end like the HP2 did.
Pre mix oil cycles through your motor rather quickly. If you feel the need to remove "old" premix you're not getting any advantage IMO. For if you switch to brand X it will quickly replace the 927 at the bottom of your crank after a few hours anyway. :thumbsup:
Anyone else have trouble with Honda's HP2? I always thought it was good stuff?
Why are you guys running HP2? Yamalube 2R is great stuff, you guys don't like it?
MAX!!!
yamalube is outdated oil. so much more has developed in the world of premix since that oil came out. and it has yet to be updated. i run castrol ttr. stuff is amazing. smells great, have yet to foul a plug still, and muuuch less measurable wear than with yamalube.
I never had any issues with the HP2 stuff running it at 32:1. It smoked less, didnt spooge and didnt cause any abnormal wear
Thanks this is good useful information.
the oil debates are always a joy. there are brand loyalists, dealer rec loyallists and cheapskates. I fall into cheapskates. I have several 2t engines and many snowmobiles (which burn about 10gal of fuel a day) I have one sled, a 1997 yammy that has seen every brand of "cheap" oil. it has over 7000 miles on it now. 4000 miles is considered "wore out" for a mtn sled. my long term testing has told me this......all oil lubricates. some oil smells better, worse different then others. some do seem to cause a bit more gunk on power valves. thos that do gunk the power valves oils that I would trust for longer term storage of a 2t engine, they are typically dino oils that tend to "stick" to the crank better and not allow moisture in there place. full synthetic seem to be a poor choice for longer term storage, but do a fine job of lubricating......nearly as good as what you can go down to the auto store and buy.
my advice for oil after a rebuild is.....pick one, make it plenty rich the first couple tanks and then enjoy.
You wont really know how good an oil is until you stress it beyond its ability to lubricate. Call it the "safety zone" and the HP2 has a narrow one.
In my case, my motor is a YZ 144 that pumps out nearly 40HP on the dyno at 11k RPM. The race fuel I use is off the charts in order to control detonation.
So all that said, HP2 did not cut it under this kind of abuse. I'M sure many have had no problems with HP2 under normal conditions.
Like with fuel and tuning a motors octane needs, the quality of your oil needs to be evaluated in the same way and how much of a "safety zone" you need.
I run Walmart brand supertech outboard oil in my 01 yz250. I beat the living hell out of my engine!! Absolutely zero problems, I was running blendzol but supertech is 40 bucks cheaper for a gallon! My bike runs awesome dont believe the hype that you need more expensive oil.
plus one
Ah, oil discussions...... Pick one, jet accordingly and you should not have problems. Run dirt cheap oil, run $8 a pint oil, all up to you. I run hp2 in mine and jet correctly and have NO PROBLEMS. I run mine between low/mid rpm single track and WFO on transfers from single track to single track and have not had problems with lack of lubrication. The important thing is to JET JET JET!
I agree, riders that trail cruise or ride mostly stock can run the cheap stuff, some even claim they can run 100 to 1 ratios. Only an idiot would do that, but it happens.
But one thing I do know, If I ran the gas oil mix that most here can get away with in my motor it would grenade.
125/ 144 riders that ride mx should use the best oil they can find, 250 riders not such a big deal as most can't run it hard enough to matter unless the 250 is pushing well over 50HP.
I wish someone would come on here with scientific evidence that their oil selection directly caused engine meltdown. It be nice to have scientific proof documenting that.
there was a test that was posted on snowest a few years back..........saved me a boat load of money.
  • Similar Content
    • By Lone Danger
      Ok so I'm looking for opinions from those who have been on yz125s and 150 exc/xcw's and maybe the ktm 200's exc/xcw's. You gotta be out there.
      Here's the deal...I'm 5'7" 165lbs. A couple years back I was looking for a small bike for my wife to learn on and for me to play around with and race. Could only afford one bike. I got a '09 ktm 105 sx. Once I got it sprung for my weight it was great. I have been top five consistently in my local harescrambles B class, believe it or not. Ya, you were not the only ones shocked. And did pretty good in the local mx races as well, junior class up here in Canada. Lack of power was sometimes an issue but I learned to deal with it and just scream, scream, scream!
      However my wife is a complete beginner and she is scared of it. I have since moved her to a 4 stroke.
      Just got a mint '01 yz15 mid summer. Like less than 200 hrs! I have absolutely loved it on the mx track. Suspension is perfect and I love the extra power. I had planned to set it up for woods/mx with a suspension revalve. However, did a harescramble race a month ago that was really technical. Granted I have not done anything to the suspension minus clickers, had too much psi in the tires (13 front and 15 rear) (yes I know that's wonkey, I only had time to get a heavy duty tube in the front and had a stock tube in back. Less psi in the back would have been instant pinch flat because its so rocky) and it was running rich. I had to scream the thing to keep it running and even changed a plug mid race. Well I'm sure you can guess but it was the worst experience I have ever had on a motorcycle. The more open sections I passed a lot of people but the tech sections required way more effort than I liked and the suspension beat the hell out of me!!! Like my knees, wrists, and shoulders were just done. (I was out there for three hours).
      So keep in mind that I just came off a 105sx with suspension mods (set up for woods/mx). I have no problem slipping clutch and shifting precisely, yatta yatta. (I don't think the 105 would have done well here either due to even less power, however...) I've been second guessing fixing this 125 up for woods ever since I rode a friends '09 ktm 250xcw. I rode it on a local mx track. The power was just so effortless and I was absolutely floored by how the suspension worked. I never thought that I could hit the woops that hard and clear every jump on the track on an xcw and feel THAT good! It felt a lot heavier though, and I think the price tag on these things are going to be a stretch.
      So here's my question. I want the lightness of a 125, but want to be able to race both woods and mx. How does a 150 exc/xcw ENGINE compare to an mx 125 engine? I love the 125 engine, but more low end would be usefull in tech areas. But if there is not a huge difference, I will probably just revalve the yz for woods and go tubless, etc. The 150exc's are so expensive and I hardly ever even see one for sale unless its brand new. I don't want the weight of a 200/250/300. I barely touch the ground on a 125....so it has to at least be light. Is it worth waiting for a 150 engine? Thanks guys.
    • By doolan
      Hi guys I have a 2018 yz250 looking at changing springs front and rear I'm 200 pound ride b class moto.
      Having problems choosing spring weights using the calculators as mx tech say I need .45 fork springs and 5.2 rear but racetech say .48kg forks and 5.8kg rear.
      What are other bigger guys
    • By YamahaYz1
      Hey TT, I know there's endless topics on YZ250/ two stroke tuning in general but I have not been able to find one that helps me get my 09 YZ250 set up for my riding style and where I ride so I'm here asking for help. I got this bike around 1.5 years ago and have not known how to set it up properly. I know no one can give me a perfect set up but I'd like a good starting setup to work from and tweak to perfection. Throughout this time I've had this bike, its always been covering the bottom of the entire silencer and dripping all over the swing arm and rims with oil. Also, the joint between silencer and expansion pipe has oil around it too but I've heard I have to close the gap a little to squeeze the silencer a little tighter and stop the leakage there. I don't have too much experience messing with carbs but I've messed around with previous two strokes and tuned them a little better. I change the oil on my bike after 15-20 hours on it and clean and oil the air filter after almost every ride. The sparkplugs never last me more than a few months but recently have been lasting me no more than a few weeks. With the excess oil from the pipe and spark plug fouling you can see why I need to set my bike up to stop this.
      The bike:
      Completely stock with V-Force 3 Reeds and a FMF Shorty silencer.
      Usually running around 32:1 premix with 91 pump fuel because I prefer to keep it well lubricated instead of running rich.
      Riding:
      I ride enduro in Ontario, Canada. So mostly single track and some fire roads but nothing close to MX and not a lot of time wide open. Therefore, probably mostly 1/4-1/2 or 1/4-3/4 throttle range.
      Where I ride:
      Usually 0-500' above sea level. With temperatures ranging from around 15-35 degrees Celsius (55-95 Fahrenheit).
      If anyone can give me a setup to go from, that would be very much appreciated. Even multiple set ups for different temperature ranges or any suggestions would be much appreciated. Thanks and sorry for the long read, I just didn't want to leave anything out. Ask any questions if you have any, too.
    • By Goon Rides
      Hey guys... so I have a problem... I took the bike at Cal City, broke it in, and while I was doing so, the bike was bogging in first gear (Yes, first gear). Also it doesn't idle at all. I have to keep blipping it otherwise it'll stall. So I adjusted the screw circled in image 1. Well I was listening to the sound of the of the bike, yet the rpm's weren't increasing, and it was still stalling. So then, I unscrewed the screw in image 2, well I found out that it was fully twisted to the right. So then, I twisted it to the left, still nothing; it was still stalling... where's the idle screw? I am sure that the screw in image 1 is for the air/fuel mixture screw, and the screw in image 2 is the idle screw, just broken? I don't know, any and every help would be appreciated.
