KDX 220 clutch problems
I have an 02 kdx 220. The clutch is sticking, so when i put it in gear it, it wants to jump forward. It's like you don't have a clutch, but after i warm it up and ride it around for awhile, it works fine. Is there anything i can do to fix this problem?
Make sure your clutch is adjusted correctly and an oil change wouldn't hurt.
Sometimes clutch plates stick together when they've been sitting a while. Once the bike heats up they seperate
What trans oil are you using? Did it just start doing this?
My 03 kdx 200 does this every time I start it. I just cleaned the entire thing getting ready for spring break and filled it with a rich oil gas mix 32:1 for the first start up, plus provides more lube and better power (more oil = better seal for more compression) and the clutch was sticking on the first kick. I changed the gear lube after I rode it for awhile around the yard. Then I put fresh lube and let it sit with the clutch lever tie wrapped to the bar. I started it today and the clutch still sticks.... its just the way they are. I've owned this bike for a year and put 2000 miles on it last season (all trails). The bike "jumps" every time I start it up fresh and hit first.
I'm thinking about switching over to ATF, I'm running "clutch saver 10x30" right now, and always have.
I changed the oil and just zip tied the clutch lever down. c if that;ll do anything...it's been sitting since fall. I'm thinking of taking the clutch apart to c if the basket is wore any
The viscosity of the oil you run will have a lot to do with your problem. If you are running 30wt dino oil the problem will be worse then if you are running 10-50wt Shell Rotella Syn or ATF. No matter what you run it will still stick a bit when the engine is cold. Just hold the front brake and give it a throttle blip when you put it in gear. If the clutch is still dragging after the engine has warmed up then your clutch lever is out of adjustment or you have other problems.
My basket was notched real bad and I had the EXACT same thing as you. Filed them down, and voila no more.
took the clutch apart. basket case has grooves in it, i filed them down and it works pretty dog gone good not
  • Similar Content
    • By jace kornegay
      I have a problem with my stage 2 exhaust cam on my rmz whenever I kick it over the exhaust cam likes to stop at the lift unless I put it at tdc or kick it really slow it runs fine when it starts and I have played around with the shims right now all the valves are shimed and I have checked the timing everything’s to spec it just gets stuck at the exhuast I’m pretty sure it’s something to do with too much compression I probally will end upbuying stock cams but wanted to see if anyone knows how to fix this first
    • By frontline510
      I recently acquired a 1990 KDX200. The bike runs reasonably well for it's age. The first ride over 30 min the gearbox oil started overflowing into the airbox (overflow hose is routed to airbox). The oil that overflowed and the oil in the gearbox are an odd shade of dark forest green. The oil appeared to be overfilled slightly which explains the overflow. What I don't understand is the weird dark blueish greenish gray color of the oil.  I believe the PO used motul 10w40 ester gearbox oil because he gave me a half used gallon. I use Motul 710 2t oil which is blue, and run green coolant in the radiator. I drained the gearbox oil and there was a nice little clump of dark gray metalic paste on the magnetic drain plug, which should explain the gray hue. What I do not understand is the greenish blue hue. Anyone know what in the heck is going on with this old horse?
      The pic shows a sample of my drained oil. When held up to the light it turns more of a green color. Oil still feels slick as can be.
    • By 2strokeKyle
      I am wondering how a kx125 will do at at Glaims. I am 14 years old 5 foot 4 inches  and 100 pounds. I will have a paddle tyre in the back too.
    • By Snox90
      will a clutch basket from a 98kx250 fit a 96kx250? How about the carb also?
    • By Kaelan Frost
      I have a new cylinder that i bought to rebuild my 1993 kawasaki kx250 with, because the old cylinder was destroyed. The guy said the cylinder is overbored a little but never gave us numbers. The new one i bought came with a piston thats been used and i would like to replace. I believe the piston that came with the cylinder is the correct size, but it very well could be off and i have no way of knowing. So how do i properly measure the cylinder bore, and how do i use this measurement to find what size piston I need to get?
      thanks,
      Kaelan
