DR350 tach problem
My 99 DR350se's stock tach quite working the other day while I was tearing down a dirt road. I've inspected the wiring behind the headlight fairing and can't find any splits or loose connections. Any suggestions on where to start investigating next and will a simple wire tester be able to tell me if those wires are getting a signal?
Three wires for the tach:
Orange wire is + 12 volts
Black with white stripe is ground
White with red stripe is the tach signal line from the CDI box. No one knows if it is a variable dc voltage or AC pulses on this line. I have never measured it myself.
mine quit once when the ground wire separated INSIDE the wiring harness. That was hard to find!
